I use connect-3-pro cards on hp machines to boot via ipxe but getting attached errors. Apparently, the iPXE does not support connect-3-pro cards. just wondering is there any chance to add ipxe support for the cards.
Thanks,
Bal
Hi Bal,
Based on the ‘flint’ output you are using a Mellanox HP OEM card (HP Ethernet 10Gb 2-port 546FLR-SFP+ Adapter (779799-B21). Based on this information, you should contact HP for support as HP is capable of changing the capabilities for this adapter.
Thanks and regards,
~Mellanox Technical Support
Hi Bal,
Thank you for posting your question on the Mellanox Community.
Based on the information provided, you maybe running an outdated version of Flexboot/UEFI on your ConnectX-3 Pro.
Please open a Mellanox Support so you can request the latest available version applicable for your ConnectX-3 Pro.
Thanks and regards,
Here is the fw details of the card. I think those are the latest.
flint -d /dev/mst/mt4103_pciconf0 q
Image type: FS2
FW Version: 2.42.5000
FW Release Date: 5.9.2017
Product Version: 02.42.50.00
Rom Info: version_id=8025 type=CLP
type=UEFI version=14.11.45 cpu=AMD64
type=PXE version=3.4.752
Device ID: 4103
Description: Node Port1 Port2 Sys image
GUIDs: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff
MACs: 70106fa0f9b0 70106fa0f9b1
VSD:
PSID: HP_2240110004
Also, I couldn’t find the connectx-3 pro cards in the hardware list that expected to work: iPXE - open source boot firmware [appnote:hardware_drivers] iPXE - open source boot firmware [appnote:hardware_drivers]
