Not a Linux expert here - The SD card image for the Xavier NX development kit doesn’t come with all default Linux drivers. Specifically, I want to add the hid-sony driver to use a Dualshock 4 controller. Reading some similar posts, I tried to compile hid-sony.ko on the Jetson and add it to lib/modules/…/drivers/hid/ and add the driver name to /etc/modules and run sudo depmod. I’m not if this is the correct method or if I did a step wrong, as the controller still uses the hid-generic drivers when I try to connect it. Do I need to recompile the whole kernel? Thanks!
It sounds like the creation and addition steps for the module were likely correct. The problem seems to be that the device itself is saying it is a generic HID driver, and thus there is no need to try to use a different driver. You might include the full verbose “lsusb
” for the device, though I’m not sure it will help. If you run “lsusb
”, then the device will show up with an ID. I don’t know which ID your device has, but as an example, I am going to pretend the ID is “0955:7e19
”. You can find the verbose lsusb
and create a log via this:
sudo lsusb -d 0955:7e19 -vvv 2>&1 | tee log_lsusb.txt
I would hesitate to tell you to blacklist a standard driver as a default since this would cause a lot of devices to fail.
I have a real Sony controller as well as an off-brand dualshock4. I want to use the sony drivers because that allows me to control the LEDs on the controller via /sys/class/leds. I want them both to use the sony drivers via bluetooth, and I have confirmed that I can access the controller LEDs on a Linux laptop via bluetooth and USB. Neither of them seem to use the sony drivers via bluetooth on the Jetson, but via USB the real controller appears to work, while the off-brand controller is still using the generic drivers via USB. lsusb output for the off-brand controller is below:
Bus 001 Device 007: ID 054c:05c4 Sony Corp. DualShock 4
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x054c Sony Corp.
idProduct 0x05c4 DualShock 4
bcdDevice 1.00
iManufacturer 1 (error)
iProduct 2 (error)
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 467
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
Device Status: 0x0401
Self Powerede
And lsusb for the real sony controller (the off brand controller doesn’t have audio)
Bus 001 Device 009: ID 054c:09cc Sony Corp.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idProduct 0x09cc
bcdDevice 1.00
iManufacturer 1 Sony Interactive Entertainment
iProduct 2 Wireless Controller
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 225
bNumInterfaces 4
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
iInterface 0
AudioControl Interface Descriptor:
bLength 10
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 71
bInCollection 2
baInterfaceNr( 0) 1
baInterfaceNr( 1) 2
bLength 12
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0101 USB Streaming
bAssocTerminal 6
bNrChannels 2
wChannelConfig 0x0003
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 10
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 2
bSourceID 1
bControlSize 1
bmaControls( 0) 0x03
Mute Control
Volume Control
bmaControls( 1) 0x00
bmaControls( 2) 0x00
iFeature 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0402 Headset
bAssocTerminal 4
bSourceID 2
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 4
bAssocTerminal 3
bNrChannels 1
wChannelConfig 0x0000
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bUnitID 5
bSourceID 4
bControlSize 1
Mute Control
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bTerminalID 6
bAssocTerminal 1
bSourceID 5
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 1
bDelay 1 frames
wFormatTag 1 PCM
bLength 11
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 2
bSubframeSize 2
bBitResolution 16
bSamFreqType 1 Discrete
tSamFreq[ 0] 32000
bLength 9
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 9
Transfer Type Isochronous
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x0084 1x 132 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
AudioControl Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bLockDelayUnits 0 Undefined
wLockDelay 0 Undefined
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 6
bDelay 1 frames
wFormatTag 1 PCM
bLength 11
bDescriptorType 36
bNrChannels 1
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 16000
bLength 9
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 5
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0022 1x 34 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 507
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
Device Status: 0x0000
(Bus Powered)```
I just want to point out some details which might be points of confusion (and I don’t have one of these devices, so that is all I can do)…
Each USB device can have multiple devices on a single cable. Take a look at the number of occurrences of:
bInterfaceClass
This which are Human Interface Device (HID), Audio, so on, are mostly something you wouldn’t change when they are “standard” classes unless there is a udev
rule intercepting this device via some special criteria, e.g., based on serial number or brand. Unless you have such a udev
rule to intercept by means of some special criterion, then USB is working as intended.
So it looks like you need to create your own custom udev
rule if you really want to use a non-standard driver. For that purpose you would need to find your method of detecting the specific device.
The normal ID might have a serial number, but often serial numbers are not burned into individual USB devices unless it is something like a key dongle. In your case both have idVendor
of “0x054c
”, but your knock-off device has a different idProduct
(it is a bad clone…mostly I’d advise to not use it). The off-brand device is idProduct
of “0x5c4
”, while the real device has idProduct
of “09cc
”. The combination of idVendor
and idProduct
could be used to identify the knock-off device in a udev
rule. That rule can name the driver, or even rename the device in the “/dev
” files (or a combination).
There are a lot of articles on the web for how to work with udev
. An example you might take a look at:
https://linuxconfig.org/tutorial-on-how-to-write-basic-udev-rules-in-linux
Do realize though that you very very definitely should not alter USB itself to use the wrong driver because it will use the wrong driver for everything, not just what you want it to work with.
