I checked the adv748x source code and it is doing the probe operation correctly. I also checked the port bindings again and it is also correct. I am sharing the dtsi and dts files one by one below.
//This document: tegra234-adv7480-driver.dtsi
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#include <dt-bindings/gpio/tegra234-gpio.h>
#include <dt-common/jetson/tegra234-p3767-0000-common.h>
#define PORT_INDEX 2
#define BUS_WIDTH 4
tegra-capture-vi {
nvidia,vi-mapping =
<0 0>,
<1 0>,
<2 0>,
<3 0>,
<4 1>,
<5 1>;
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
adv7480_vi_in0: endpoint {
port-index = <PORT_INDEX>;
bus-width = <BUS_WIDTH>;
remote-endpoint = <&adv7480_csi_out0>;
host1x@13e00000 {
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
adv7480_csi_in0: endpoint@0 {
remote-endpoint = <&adv7480_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
adv7480_csi_out0: endpoint@1 {
remote-endpoint = <&adv7480_vi_in0>;
hdmi-in {
compatible = "hdmi-connector";
label = "HDMI IN";
type = "a";
port {
hdmi_in_con: endpoint {
remote-endpoint = <&adv7480_hdmi>;
i2c@c240000 { // HDMI or SDI
adv7480:adv748x@70 {
#size-cells = <0>;
compatible = "adi,adv7481";
/* I2C device address */
reg = <0x70 0x73 0x74 0x75
0x60 0x62 0x63 0x64 0x65>;
reg-names = "main", "hdmi", "edid", "repeater",
"infoframe", "cec", "sdp", "txa", "txb";
devnode = "video0";
interrupt-parent = <&tegra_main_gpio>;
interrupt-names = "intrq1", "intrq2";
interrupts = <TEGRA234_MAIN_GPIO(I, 0) GPIO_ACTIVE_HIGH>,
<TEGRA234_MAIN_GPIO(I, 1) GPIO_ACTIVE_HIGH>;
/* Physical dimensions of sensor */
physical_w = "4.713";
physical_h = "3.494";
sensor_model = "adv7480";
mode0 { // E2832_1920x1080_60Fps
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
mode_type = "rgb";
pixel_phase = "rgb888";
csi_pixel_bit_depth = "24";
readout_orientation = "0";
line_length = "1920";
inherent_gain = "1";
mclk_multiplier = "24";
pix_clk_hz = "250000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "60000000"; /* 60.0 fps */
step_framerate = "1";
default_framerate = "60000000"; /* 60.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
step_exp_time = "1";
default_exp_time = "16667"; /* us */
mode1 { // E2832_3840x2160
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "3840";
active_h = "2160";
mode_type = "rgb";
line_length = "3840";
pix_clk_hz = "500000000";
gain_factor = "16";
mode2 { // E2832_1280x720_60Fps
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
mode_type = "rgb";
line_length = "1280";
gain_factor = "16";
ports {
#size-cells = <0>;
port@8 {
reg = <8>;
adv7480_hdmi: endpoint {
remote-endpoint = <&hdmi_in_con>;
port@a {
reg = <10>;
adv7480_out0: endpoint {
clock-lanes = <0>;
data-lanes = <1 2 3 4>;
remote-endpoint = <&adv7480_csi_in0>;
tcp: tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
cam_module0: module0 {
badge = "hdmi_input";
position = "top";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "adv7480 1-0070";
proc-device-tree = "/proc/device-tree/i2c@c240000/adv748x@70";
//This document: tegra234-p3767-camera-adv7480.dtsi
* Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include "tegra234-adv7480-driver.dtsi"
#define ADV_RST TEGRA234_AON_GPIO(CC, 3)
#define CAM0_PWDN TEGRA234_MAIN_GPIO(H, 6)
i2c@c240000 {
adv748x@70 {
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
clocks = <&bpmp_clks TEGRA234_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA234_CLK_EXTPERIPH1>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
reset-gpios = <&tegra_aon_gpio ADV_RST GPIO_ACTIVE_HIGH>;
vana-supply = <&p3509_vdd_3v3_sys>;
vdig-supply = <&p3509_vdd_3v3_sys>;
gpio@c2f0000 {
camera-control-output-high {
gpio-hog;
output-high;
gpios = <CAM0_PWDN 0>;
label = "cam0-pwdn";
//This document: tegra234-p3767-camera-adv7480-driver.dts
// SPDX-License-Identifier: GPL-2.0-only
* Jetson Device-tree overlay for ADV7480
* Copyright (c) 2021-2023 NVIDIA CORPORATION. All rights reserved.
/dts-v1/;
/plugin/;
overlay-name = "HDMI Camera Driver ADV7480";
jetson-header-name = "Jetson Nano CSI Connector";
compatible = "JETSON_COMPATIBLE_P3509","nvidia,p3509-0000+p3767-0000", "nvidia,p3509-0000+p3767-0001", "nvidia,p3509-0000+p3767-0002", "nvidia,p3509-0000+p3767-0003";
/* VI number of channels */
fragment@0 {
target-path = "/tegra-capture-vi";
board_config {
sw-modules = "kernel";
__overlay__ {
nvidia,vi-mapping =
<0 0>,
<1 0>,
<2 0>,
<3 0>,
<4 1>,
<5 1>;
num-channels=<1>;
fragment@1 {
target-path = "/tegra-capture-vi/ports/port@0";
board_config {
__overlay__ {
status = "okay";
fragment@2 {
target-path = "/tegra-capture-vi/ports/port@0/endpoint";
board_config {
__overlay__ {
status = "okay";
port-index = <2>;
bus-width = <4>;
fragment@3 {
target-path = "/host1x@13e00000/nvcsi@15a00000";
board_config {
__overlay__ {
num-channels = <1>;
fragment@4 {
target-path = "/host1x@13e00000/nvcsi@15a00000/channel@0";
board_config {
__overlay__ {
status = "okay";
fragment@5 {
target-path = "/host1x@13e00000/nvcsi@15a00000/channel@0/ports/port@0";
board_config {
__overlay__ {
status = "okay";
fragment@6 {
target-path = "/host1x@13e00000/nvcsi@15a00000/channel@0/ports/port@0/endpoint@0";
board_config {
__overlay__ {
status = "okay";
port-index = <2>;
bus-width = <4>;
fragment@7 {
target-path = "/host1x@13e00000/nvcsi@15a00000/channel@0/ports/port@1";
board_config {
__overlay__ {
status = "okay";
fragment@8 {
target-path = "/host1x@13e00000/nvcsi@15a00000/channel@0/ports/port@1/endpoint@1";
board_config {
__overlay__ {
status = "okay";
fragment@9 {
target-path = "/i2c@c240000/adv748x@70";
board_config {
__overlay__ {
status = "okay";
fragment@10 {
target-path = "/tegra-camera-platform";
board_config {
__overlay__ {
fragment@11 {
target-path = "/tegra-camera-platform/modules/module0";
board_config {
__overlay__ {
status = "okay";
position = "top";
orientation = "1";
fragment@12 {
target-path = "/tegra-camera-platform/modules/module0/drivernode0";
board_config {
__overlay__ {
status = "okay";
I call the file named tegra234-p3767-camera-adv7480.dtsi in the file named tegra234-p3509-a02.dtsi. Then when I build the kernel, I use the file named tegra234-p3767-0000-p3509-a02.dtb and throw it into the jetpack. In the Linux for tegra folder in the jetpack, I edit the following section in the p3767.conf.common file;
OVERLAY_DTB_FILE=“L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo,tegra234-p3767-camera-adv7480-driver.dtbo”;
Then I do the flashing process. Is there anything wrong so far?
