AGX Orin getting stuck booting on a custom board
We have a custom baseboard for a AGX Orin and getting stuck in the following location:
Boot log
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x102d980000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Check MC errors
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock...
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x1032000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
E> eeprom: Retry to read I2C slave device.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
Design information
  • We are using a AGX module from a dev kit (assume it is booting from eMMC).
  • there is not an EEPROM on the baseboard.
We found this doc that states the eeprom is optional.
Questions:
  • What is the process for modifying this file?
  • What are the implications for the system if you don’t have an eeprom?
  • Does the eeprom have to be programmed for the system to boot, or only present?
Modifying the EEPROM
EEPROM is an optional component for a customized carrier board. When the carrier board is designed without an EEPROM, in the Linux_for_Tegra/bootloader/tegra234-mb2-bct-common.dtsi (the MB2 BCT file), make the following modification:
- cvb_eeprom_read_size = <0x100>
+ cvb_eeprom_read_size = <0x0>
