Based on the provided context, I’ll provide a comprehensive answer to your question.
Background
You were experiencing occasional kernel panic issues under Jetpack 5.1.2 when restarting camera streaming on Jetson AGX Orin. The problem was solved with a patch, and the details can be found in the topic “Kernel panic when camera streaming restarts Jetson AGX Orin”.
Current Situation
You are now moving to Jetpack 6.2 and are concerned that the patch may not be applied in this version. After checking the source code, you suspect that the patch may not be included in Jetpack 6.2.
Analysis
To determine if Jetpack 6.2 requires a similar patch, we need to analyze the changes made in Jetpack 6.2 compared to Jetpack 5.1.2. Unfortunately, the provided context does not contain information about the specific changes made in Jetpack 6.2.
However, we can look at the general information about Jetpack 6.2. According to the context, Jetpack 6.1 GA is a software package for AI applications, and Jetpack 6.2 is likely a subsequent version. It is possible that the kernel panic issue was addressed in another way in Jetpack 6.2, but without more information, we cannot confirm this.
Comparison with Other Issues
We can look at other issues reported in the context to see if there are any similar kernel panic issues reported for Jetpack 6.2. One issue that stands out is the “Kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!” reported for Jetson Xavier NX. Although this issue is not directly related to camera streaming, it does indicate that there may be kernel-related issues in Jetpack 6.2.
Conclusion
Based on the provided context, it is unclear if Jetpack 6.2 requires a similar patch to address the kernel panic issue when restarting camera streaming. Without more information about the changes made in Jetpack 6.2, we cannot confirm if the issue was addressed in another way. It is recommended to further investigate the changes made in Jetpack 6.2 and to test the camera streaming functionality to determine if the issue still exists.
Recommendation
To resolve this issue, you may want to:
- Check the Jetpack 6.2 release notes and documentation to see if there are any known issues or fixes related to kernel panic or camera streaming.
- Test the camera streaming functionality on Jetpack 6.2 to determine if the issue still exists.
- If the issue still exists, consider reaching out to NVIDIA support or the Jetpack community for further assistance.
