We are experiencing reproducible packet reordering during 10GbE transmission from Jetson AGX Thor (T264) using the stock nvethernet driver on L4T r39.2.1. This issue causes spurious TCP retransmissions and persistent UDP out-of-order delivery.
Our investigation shows that packets are transmitted in sequence in sender-side captures, but the Intel X710 receiver observes a recurring three-packet reordering pattern. The reverse direction (X710 → Thor) does not exhibit this behavior.
These results suggest that packet reordering occurs somewhere in the Thor MGBE TX path, rather than at the application level. However, the exact cause has not yet been identified, and we would like NVIDIA’s assistance in determining whether this is a known hardware or driver issue and identifying a possible fix or workaround.
[ Test environment ]
· Hardware: two Jetson AGX Thor Developer Kits and one custom carrier board with the same Thor module.
· Software: L4T r39.2.1; kernel 6.8.12-1021-tegra; stock nvethernet driver.
· Thor Ethernet interface: mgbe1_0 (a808b10000.ethernet), 10GbE direct back-to-back link (no switch).
· MTU: mgbe1_0 mtu 9000; reported MTU 8966 in this setup (34-byte MACsec-related reduction).
· Reference peer: x86 PC with Intel X710 (i40e), 10GbE, MTU 8966.
[ symptoms ]
1 TCP: retransmissions early in the test
* PC (client) → thor (server)
* PC (server) ← thor (client)
The retransmission count (53) matches the number of duplicate segments reported through DSACK (TcpExtTCPDSACKRecvSegs = 53), although the DSACK receive count is slightly lower (51). Together with the high TcpExtTCPSACKReorder count (33,201), these results strongly suggest that many TCP retransmissions may be spurious and triggered by packet reordering rather than permanent packet loss.
However, the counters alone do not conclusively prove that every retransmission was unnecessary.
2 UDP: persistent out-of-order delivery
*PC (server) ← thor (client)
[ Observed packet sequence pattern ]
Receiver captures show a recurring group-of-three pattern in the affected conditions: {N, N+1, N+2} is observed as {N+2, N, N+1}.
Expected: 1001 1002 1003 1004 1005 1006 1007 1008 1009 …
Observed: 1003 1001 1002 1006 1004 1005 1009 1007 1008 …
[ Direction Comparison and Localization ]
X710 → Thor TCP achieved approximately 9.89 Gbit/s with zero retransmissions;
Thor → X710 showed retransmissions/DSACK and high SACK-reordering counters.
UDP capture analysis likewise showed no packet reordering for X710 → Thor, while significant packet reordering was observed in the reverse direction (Thor → X710) under the tested conditions.
[ Questions ]
Q1. Is packet reordering on the T264 MGBE transmit path (PDMA/VDMA/MTL TX) a known issue for L4T r39.2.1?
Q2. Are there recommended registers, device-tree properties, driver patches, or DMA/queue configurations to preserve per-flow packet order at 10GbE?
