Hello Wayne,
Is this patch for JetPack 4.4 or 4.5?
Am I right that I apply the patch to my Tegra_for_Linux installation and then flash my Xavier AGX again?
Hello Wayne,
Both jp4.4.1 or 4.5.1 can apply this. You need to rebuild both kernel image and dtb.
I have a hard time identifying the correct files, which one must be patched?
~/Linux_for_Tegra/sources$ find . -name 'bluedroid_pm.c'
./kernel/kernel-4.9/drivers/misc/bluedroid_pm.c
./kernel/nvidia/drivers/misc/bluedroid_pm.c
Is this the correct file?
~/Linux_for_Tegra/sources$ find . -name 'tegra194-p2888-0001-p2822-0000-common.dtsi'
./hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
Please use the one in kernel-4.9.
Yes, this is the correct file.
~/Linux_for_Tegra/sources$ find . -name ‘tegra194-p2888-0001-p2822-0000-common.dtsi’
Hello Wayne,
thanks for constant support. (I think) I have build kernel image and dtd by following instructions of https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/kernel_custom.html documentation (except the optional step no. 8)
Am I now ready for ./flash
and do I have to use -r
option or not?
Please make sure the dts and image file are put into the Linux_for_Tegra/kernel/dtb and Linux_for_Tegra/kernel/. Running the flash.sh without -r.
The “-r” option is to re-use previous system.img. We should do a clean setup at this moment so do not use -r.
Looks like I have succesfully applied the patch. My Xavier AGX DevKit is now running for more than 3 hours in MAXN mode while performing a CPU&GPU hungry task (Training of a Tacotron2 TTS model). No freeze or shutdowns so far. The “bluetooth hostwake” proc counter, which went up before, is still at “0”.
I will keep this running for another 24h and report back again…
Thanks. Waiting for your reply.
My Xavier-AGX is running now for more than 60 hours (about 48h in MAXN mode) without any issues.
Will the Patch be included in a future JetPack Release (4.5.x)?
We will try to merge it so it will be in next release.
Did this make it into Jetpack 4.6?
same question as snarky, did this make it into 4.6?
thanks
Don’t know who you are adressing. I didn’t install 4.6 yet…
Maybe @WayneWWW can confirm if the bluedroid-patch made it into JetPack 4.6?
Sorry that it looks like those patches are not yet merged…
I will check what is going on internally. Currently still need to manually add this to your driver/dts.
@dkreutz Where did you find the flash.sh script? I’m looking in the Linux for Tegra download and I don’t see it. Thanks!
What does your Linux_for_Tegra look like? If even flash.sh is not there, you probably using the wrong file.
