All my messages on REDIS are missing the classification % on the last parameter like this example:
'{ "version" : "4.0", "id" : "348945", "@timestamp" : "2024-08-13T14:10:05.137Z", "sensorId" : "video_test", "objects" : [ "39634|361.462|475.645|405.39|591.268|Person|**0**", "39625|422.592|489.527|461.835|585.446|car|**0**" ] }'
“39634|361.462|475.645|405.39|591.268|Person|0”
I am using a clean AI_NVR installation container + Yolo standart Deepstream container on Jetson AGX Orin Dev 64GB
How can i solve it?
kesong
3
I can reproduce it. I will check more and feedback.
kesong
4
You can apply below patch to fix the issue. Why you need the confidence value in your project?
/opt/nvidia/deepstream/deepstream-7.0/sources/apps/sample_apps/deepstream-test5/deepstream_test5_app_main.c
@@ -526,6 +526,8 @@ generate_event_msg_meta (AppCtx * appCtx, gpointer data, gint class_id, gboolean
meta->bbox.width = obj_params->rect_params.width * scaleW;
meta->bbox.height = obj_params->rect_params.height * scaleH;
+ meta->confidence = obj_params->confidence;
/** tracking ID */
meta->trackingId = obj_params->object_id;
I need the confidence value to control the threshold on my app-config, is there another way to configure it on deepstream config files?
I Will test the solution.
