I simulated the air flow in a room through the diffuser, but it’s seems doesn’t work well. The air flow stuck above the diffuser and doesn’t affect in the room.
I created three different zones and controlled their batch sizes, as shown in the picture below with the inlet flow coming from the top.
Does anyone know what’s this problem?
here is my code
#params
nu=0.01
rho=1.0
inlet_vel=2.63
#geometry
geometries = Build_Geometry()
geo_wall :Geometry = geometries.wall
geo_interior :Geometry = geometries.interior
geo_s_interior_1 :Geometry = geometries.s_interior_1
geo_s_interior_2 :Geometry = geometries.s_interior_2
geo_inlet_1:Geometry = geometries.inlet_1
geo_inlet_2:Geometry = geometries.inlet_2
geo_outlet:Geometry = geometries.outlet
geo_diffuser_1 = geometries.diffuser_1
geo_diffuser_2 = geometries.diffuser_2
x, y = Symbol("x"), Symbol("y")
# make list of nodes to unroll graph on
ze = ZeroEquation(nu=nu, rho=rho, dim=2,max_distance=(4.2) / 2)
ns = NavierStokes(nu=ze.equations["nu"], rho=1.0, dim=2, time=False)
normal_dot_vel = NormalDotVec(["u", "v"])
flow_net = instantiate_arch(
input_keys=[Key("x"), Key("y")],
output_keys=[Key("u"), Key("v"), Key("p")],
cfg=cfg.arch.fully_connected,
nodes = (
ns.make_nodes()
+ ze.make_nodes()
+ normal_dot_vel.make_nodes()
+ [flow_net.make_node(name="flow_network")]
# make domain
domain = Domain()
# inlet
inlet_1 = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=geo_inlet_1,
outvar={"u": 0, "v": inlet_vel},
batch_size=cfg.batch_size.inlet,
domain.add_constraint(inlet_1, "inlet_1")
inlet_2 = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=geo_inlet_2,
domain.add_constraint(inlet_2, "inlet_2")
# outlet
outlet = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=geo_outlet,
outvar={"p": 0},
batch_size=cfg.batch_size.outlet,
domain.add_constraint(outlet, "outlet")
#diffuser
diffuser_1 = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=geo_diffuser_1,
outvar={"u": 0, "v": 0},
batch_size=cfg.batch_size.diffuser,
domain.add_constraint(diffuser_1, "diffuser_1")
diffuser_2 = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=geo_diffuser_2,
domain.add_constraint(diffuser_2, "diffuser_2")
#wall
wall = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=geo_wall,
batch_size=cfg.batch_size.wall,
criteria=y < 3.5098,
domain.add_constraint(wall, "wall")
# interior flow
interior_flow = PointwiseInteriorConstraint(
nodes=nodes,
geometry=geo_wall-geo_s_interior_1-geo_s_interior_2,
outvar={"continuity": 0, "momentum_x": 0, "momentum_y": 0},
batch_size=cfg.batch_size.interior_flow,
compute_sdf_derivatives=True,
lambda_weighting={
"continuity": Symbol("sdf"),
"momentum_x": Symbol("sdf"),
"momentum_y": Symbol("sdf"),
domain.add_constraint(interior_flow, "interior_flow")
s_interior_flow_1 = PointwiseInteriorConstraint(
nodes=nodes,
geometry=geo_s_interior_1 - geo_diffuser_1,
batch_size=cfg.batch_size.s_interior_flow,
lambda_weighting={
domain.add_constraint(s_interior_flow_1, "s_interior_flow_1")
s_interior_flow_2 = PointwiseInteriorConstraint(
nodes=nodes,
geometry=geo_s_interior_2 - geo_diffuser_2,
lambda_weighting={
domain.add_constraint(s_interior_flow_2, "s_interior_flow_2")
# add inferencer data
#{x: (0.0, 4.2), y: (0.0, 3.5098)}
no_slip = geo_wall - geo_diffuser_1 -geo_diffuser_2
vtk_obj = VTKUniformGrid(
bounds=[(0.0, 4.2),(0.0, 3.509)],
npoints=[1024, 1024],
export_map={"u": ["u", "v"], "p": ["p"]},
def mask_fn(x, y):
sdf = no_slip.sdf({"x": x, "y": y}, {})
return sdf["sdf"] < 0
grid_inference = PointVTKInferencer(
vtk_obj=vtk_obj,
nodes=nodes,
input_vtk_map={"x": "x", "y": "y"},
output_names=["u", "v", "p"],
mask_fn=mask_fn,
mask_value=np.nan,
requires_grad=False,
batch_size=100000,
domain.add_inferencer(grid_inference, "grid_inference")
# make solver
slv = Solver(cfg, domain)
# start solver
slv.solve()
room_2d.zip (4.2 KB)
