Please find attached a recording of me reproducing the defect. I’ve also included the relevant logs.
Kindly note the line starting with:
2025-10-28 13:21:40,384 … Configuring init for 7 with config: … 'prompts': {'caption': 'Write a concise and clear dense caption for the provided warehouse video, …
It appears that the tools are using an incorrect configuration.
I now know how to reproduce the problem. This issue is not fixed in the nvcr.io/nvidia/blueprint/vss-engine:2.4.0 image, so brevlab cloud also include this issue. But it has been fixed in the latest code (That is why I couldn’t reproduce it in my previous reply).
It should be included in the next release; please wait for the official announcement for the exact date.
As a workaround, you can add the following configuration to your compose.yml file to override the code in the container with your local code for debugging.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
