I want to know what do we exactly mean by alignment requirement in coalesced memory accessing and how it affects the performance?
Thanks in advance
Thanks in advance
Basically, each thread in a block should access memory using at consecutive addresses (4, 8 or 16-byte wide elements), so that the i/o will be performed in a single operation (otherwise it might get split into 16 i/os operations, ie: 16x slower)
For example:
float_array[threadIdx.x] = x
(1-byte and 2-byte wide elements will not coalesce)
