Alloc dynamic variables "Segmentation fault"
Hi Nvidia Team,
I don’t know what was really happened, I provide an example code below i don’t know is that happening on push array or someting else
module mytype_base_module
  type, abstract :: mytype_base
    integer :: length = 0
    character(len=:),allocatable :: name
    real, dimension(:,:), allocatable :: arr(:)
    contains
    procedure,PUBLIC :: alloc_mytype_base
    procedure(i_check),PUBLIC,DEFERRED :: check
  end type mytype_base
  type,public :: mytype_arr
    class(mytype_base), allocatable :: obj
  end type mytype_arr
  interface
    subroutine i_check(me)
    IMPORT
    class(mytype_base),intent(in) :: me
    end subroutine
  end interface
  contains
  subroutine alloc_mytype_base(me, length)
  class(mytype_base),intent(inout) :: me
  integer,intent(in) :: length
  me%length = length
  allocate(me%arr(length))
  me%arr = 0
  end subroutine
  subroutine push_type(mytypes, obj)
    type(mytype_arr), dimension(:), allocatable, intent(inout)  :: mytypes
    class(mytype_base), intent(in) :: obj
    type(mytype_arr), dimension(:), allocatable :: tmp
    integer length
    if(.not. allocated(mytypes)) then
      allocate(mytypes(1))
      allocate(mytypes(1)%obj ,source = obj)
    else
      length = size(mytypes)
      allocate(tmp(length+1))
      tmp(1:length) = mytypes(1:length)
      allocate(tmp(1+length)%obj ,source = obj)
      deallocate(mytypes)
      allocate(mytypes(length+1))
      mytypes = tmp
      deallocate(tmp)
    end if
  end subroutine
end module mytype_base_module
module mytype1_module
  use mytype_base_module
  type, extends(mytype_base) :: mytype_1
    double precision,dimension(:), allocatable :: arr2
    contains
    procedure :: alloc => alloc_mytype_1
    procedure :: check => check_mytype_1
  end type mytype_1
  contains
  ! new
  type(mytype_1) function new_mytype_1(name,length) result(obj)
  character(len=*),intent(in):: name
  integer,intent(in):: length
  obj%name = name
  call obj%alloc(length)
  obj%arr = length + 1
  obj%arr2 = length + 2
  end function
  subroutine alloc_mytype_1(me, length)
    class(mytype_1),intent(inout) :: me
    call me%alloc_mytype_base(length)
    allocate(me%arr2(length))
    me%arr2 = 0
  end subroutine
  subroutine check_mytype_1(me)
    class(mytype_1),intent(in) :: me
    integer l
    print '(A,A15,i10)', me%name, " length = ", me%length
    write(*,"(2A10)") "arr","arr2"
    do l=1,me%length
      write(*,"(I10,F10.3,F10.3)") l,me%arr(l),me%arr2(l)
    end do
  end subroutine
end module mytype1_module
program main
  use mytype1_module
  type(mytype_arr), dimension(:), allocatable :: mytypes
  type(mytype_1) :: my_a, my_b
  my_a = new_mytype_1('foo',2)
  my_b = new_mytype_1('bar',3)
  call push_type(mytypes,my_b)
  call push_type(mytypes,my_a)
  call mytypes(1)%obj%check()
  call mytypes(2)%obj%check()
  call mytypes(3)%obj%check()
  print *, 'end'
end program
running on nvfortran
nvfortran ./test.f90 && ./a.out
bar      length =          3
       arr      arr2
Segmentation fault
running on others
gfortran ./test.f90 && ./a.out
bar      length =          3
       arr      arr2
         1     4.000     5.000
         2     4.000     5.000
         3     4.000     5.000
foo      length =          2
       arr      arr2
         1     3.000     4.000
         2     3.000     4.000
bar      length =          3
       arr      arr2
         1     4.000     5.000
         2     4.000     5.000
         3     4.000     5.000
 end
Hi NV team, I found an simple example for this issue
    contains
  end type mytype_arr
  interface
    IMPORT
    end subroutine
  end interface
  contains
  me%length = length
  me%arr = 0
  end subroutine
    integer length
    else
      deallocate(mytypes)
      mytypes = tmp
      deallocate(tmp)
    end if
  end subroutine
    contains
  end type mytype_1
  contains
  ! new
  obj%name = name
  end function
    me%arr2 = 0
  end subroutine
    integer l
    write(*,*) loc(me%arr), allocated(me%arr)
    write(*,*) loc(me%arr2), allocated(me%arr2)
    ! write(*,"(2A10)") "arr","arr2"
    do l=1,me%length
      ! write(*,"(I10,F10.3,F10.3)") l,me%arr(l),me%arr2(l)
    end do
  end subroutine
program main
  use mytype1_module
  type(mytype_arr), dimension(:), allocatable :: mytypes, tmp
  allocate(mytypes(1)%obj ,source = my_b)
  ! it's okay
  allocate(tmp(2))
  tmp(1:1) = mytypes(1:1)
  call tmp(1)%obj%check()
  print *, 'end'
end program
the result like following
$ nvfortran ./test.f90 && ./a.out
bar      length =          3
                 34314064  T
                 34313216  T
bar      length =          3
                 34312992  T
                        0  F
 end
$ gfortran ./test.f90 && ./a.out
bar      length =          3
       94298995767984 T
       94298995768016 T
bar      length =          3
       94298995772512 T
       94298995772544 T
 end
i think the issue happening on tmp(1:1) = mytypes(1:1) the variable of “arr” copied but “arr2” not.
thanks.
Hi jubilee2,
Thanks for the report. Most of our Fortran team is on vacation this week so I don’t have someone available to help triage this. Though in looking at the code in a debugger, it looks like “arr2” isn’t getting allocated which to me indicates that this is a compiler issue with extended types. I’ve filed a problem report, TPR #32870, and well have have engineering investigate.
-Mat
thank you for your reply. Now I found a built-in function that also works for me. the function named move_alloc
Any way my goal is to migrate an old Fortran program to GPU platform. As you know this program highly structured under object oriented programming style.
Do you have any recommend or document best read first?
For GPU programming? Do you know which parallel model you’re most interested in?
We support 4 different models.
I personally don’t use OOP style programing with GPUs given it can be difficult to manage the device data. Not that you shouldn’t use it, but I’d recommend to at least start with using CUDA Unified Memory (UM) so that the data management is handled by the CUDA driver. This is on by default with STDPAR and enabled via the flag “-gpu=managed” for the directive models. For CUDA Fortran, you’d change the allocate statements with calls to cudaMallocManaged. The caveat being that UM is currently available for dynamically allocated data. Static data still needs to be managed manually.
-Mat
Apologies for the late notification, but I was going through older reports and see that TPR #32870 was fixed in our 24.9 release.
% nvfortran -g test_v1.f90 -V24.9 ; a.out
bar      length =          3
       arr      arr2
         1     4.000     5.000
         2     4.000     5.000
         3     4.000     5.000
foo      length =          2
       arr      arr2
         1     3.000     4.000
         2     3.000     4.000
bar      length =          3
       arr      arr2
         1     4.000     5.000
         2     4.000     5.000
         3     4.000     5.000
 end
-Mat
