Consider the following minimal working example:
module lib
type FG_t
real,allocatable::g(:)
contains
procedure,private::FG_Assign
generic::assignment(=)=>FG_Assign
end type
interface operator(-)
procedure FG_Sub
end interface
contains
elemental subroutine FG_Assign(this,that)
class(FG_t),intent(inout)::this
class(FG_t),intent(in)::that
this%g=that%g
end
elemental type(FG_t) function FG_Sub(this,that)
class(FG_t),intent(in)::this
real,intent(in)::that
FG_Sub=FG_t(this%g-that)
end
end
program prog
use lib
type(FG_t)::arr(1000),arr_(SIZE(arr))
do i=1,SIZE(arr)
allocate(arr(i)%g(10))
end do
do i=1,100000
arr_=arr-1.
end do
end
This example was already discussed here.
When running the executable generated from the code with the Nvidia compiler (nvfortran 22.9 on Ubuntu 18.04.2 LTS), memory fills rapidly (which can lead to your PC crashing in the case of a higher number of iterations). Intel VTune Profiler shows that most of the memory is allocated in the line this%g=that%g
after FG_Sub
is called in the line arr_=arr-1.
The similar problem can be observed with the Intel and NAG compilers. Intel and NAG responded and agreed that it is a bug. Therefore, I would like to report this bug to Nvidia.
