Nvfortran runtime error for nested types
the following program yields a runtime error when compiled with nvfortran 22.3.0:
module module_1
  implicit none
  public :: type_1
  public :: gen_type_1
  type :: type_1
    private
    integer, dimension(:), allocatable :: numbers
  end type type_1
contains
  elemental function gen_type_1(i) result (r)
     integer, intent(in) :: i
     type(type_1) :: r
     allocate (r%numbers(1))
     r%numbers(1) = i
  end function gen_type_1
end module module_1
module module_2
 use module_1
 implicit none
 public :: type_2
 public :: foo
 type :: type_2
   type(type_1) :: value
 contains
   procedure :: get_value
 end type type_2
contains
  elemental function get_value (self) result(v)
    class(type_2), intent(in) :: self
    type(type_1) :: v
    v = self%value
  end function get_value
  subroutine foo(arr_in)
    type(type_2), dimension(:), intent(in) :: arr_in
    type(type_1), dimension(:), allocatable :: arr_cpy
    integer :: i
    allocate (arr_cpy(size(arr_in)))
    forall (i = 1:size(arr_in)) arr_cpy(i) = arr_in(i)%get_value()
  end subroutine foo
end module module_2
program t
  use module_1
  use module_2
  implicit none
  type(type_2), dimension(:), allocatable :: arr
  integer, parameter :: n = 1000
  integer :: i
  allocate (arr(n))
  do i = 1, n
     arr(i)%value = gen_type_1(0)
  end do
  call foo(arr)
end program t
The error message is
*** Error in `./test.x': double free or corruption (fasttop): 0x000000000180c6f0 ***
The call to the foo function at the very end is crucial. Without it, there is no error. I guess that all this indicates that when the nested types are freed up at the end of the function, the deallocation makes mistakes with the different levels of this type.
Best regards,
Christian
Thanks Cristian,
My best guess is that the compiler is doing some type of implicit allocation/deallocation and freeing something twice. I added a problem report, TPR#32307, and sent it to engineering for further investigation.
-Mat
