Issues with derived types and default initialisation
I have encountered two issues by setting default values in derived types and nvfortran (24.7).
First issue occurs with arrays:
program p_test_array
  implicit none
  integer, parameter :: a(5) = 2
  type foo
     integer :: i(6) = [1, a]
  end type foo
  type(foo) :: bar
  print *, bar% i
end program p_test_array
This error occurred:
nvfortran-Fatal-/opt/nvidia/hpc_sdk/Linux_x86_64/24.7/compilers/bin/tools/fort2 TERMINATED by signal 11
The second issue with pointers:
module mod
  implicit none
  integer, target :: par
contains
  subroutine set
    par = 1
  end subroutine set
end module mod
program p_test_pointer
  use mod, only: par, set
  implicit none
  type foo
     integer, pointer :: i => par
  end type foo
  type(foo) :: bar
  call set
  print *, bar% i
end program p_test_pointer
NVFORTRAN-S-0034-Syntax error at or near end of line (test2.f90: 18)
0 inform, 0 warnings, 1 severes, 0 fatal for p_test_pointer
Both examples compile fine with gfortran and ifort.
Can you have a look?
Hi t.huether,
For the first example, this appears to be a compiler issue so I went ahead an filed a problem report, TPR #36386, and sent it to engineering for investigation.
For the second example, nvfortran doesn’t support data type pointer initialization, just initialization of procedure pointers. This is expected to be supported when we release our next generation Fortran compiler based on our collaboration with the LLVM community’s “new” Flang project.
-Mat
Hi t.huether,
Engineering let me know that they were able to get TPR #36386 fixed in nvfortran’s 25.5 release.
-Mat
