Nvfortran internal compiler error using derived types with `class(*)` variable
I ran into an internal compiler error while building a larger Fortran code base (GitHub - NOAA-GFDL/FMS: GFDL's Flexible Modeling System). I created a much smaller reproducer for the error. It’s related to a variable in a derived type that is class(*).
module test_mod
implicit none
 type fmsDiagOutputBuffer_type
  class(*), allocatable :: buffer(:) !< Causing the issue
 end type
 type fmsDiagObject_type
   type(fmsDiagOutputBuffer_type),dimension(:), allocatable :: FMS_diag_output_buffers !< Type within a type.  The function func returns one of these
   contains
   procedure func
 end type
 type(fmsDiagObject_type) :: obj
 contains
  function func (this, bufferid) &
  result(rslt)
   class(fmsDiagObject_type), intent(in)     :: this
   integer, intent(in)                       :: bufferid
   type(fmsDiagOutputBuffer_type),allocatable:: rslt
   if( (bufferid .gt. UBOUND(this%FMS_diag_output_buffers, 1)) .or. &
     (bufferid .lt. LBOUND(this%FMS_diag_output_buffers, 1))) &
       write(*,*) 'get_diag_bufer: invalid bufferid given'
   rslt = this%FMS_diag_output_buffers(bufferid)
 end function
end module
I tried compiling in a container on a grace hopper system using nvfortran 25.5. I also tried on an x86 system using 25.1 and in a container using 25.7 and got the same error:
NVFORTRAN-F-0000-Internal compiler error. chk_assign_sptr: not enough dimensions 0 (test.F90: 29)
NVFORTRAN/x86-64 Linux 25.7-0: compilation aborted
If I switch the type of buffer to real, the code compiles. In my actual code, the buffer array is 5 dimensions, and going down to one didn’t change the error reported.
I successfully compiled this with gfortran, ifx, and aocc flang.
Hi Tom,
Thanks for the report and reproducing example!
I was able to recreate the error here and created issue report TPR #37631. I’ve asked engineering to investigate.
-Mat
Hi Tom,
Engineering let me know that as a work around, you can change:
with:
allocate(rslt, source=this%FMS_diag_output_buffers(bufferid))
-Mat
Thanks for the update. This type of function return occurs in a lot of places in our code base, so it would be an undertaking to implement this workaround. I’ll see if there’s desire from the team to implement it.
FWIW, I tested your repro with the Flang compiler (that , as Mat has mentioned several times, will be the foundation for an upcoming Nvidia compiler) and it is able to compile your code.
Hi Tom,
FYI, TPR #37631 has been fixed in our 25.9 release.
-Mat
