I have this test code, which should be compiled with nvfortran 24.11:
module m
implicit none
private
type :: foo_t
integer :: x = 0
contains
procedure :: do_stuff
end type foo_t
type(foo_t), parameter :: this_foo = foo_t(0)
interface
module subroutine do_stuff (foo)
class(foo_t), intent(in) :: foo
end subroutine do_stuff
end interface
end module m
The compilation fails with this error message:
NVFORTRAN-F-0155-No default initialization in structure constructor- member do_stuff$tbp$1 (constructor.f90: 12)
I’m not entirely sure if the code is correct as it is, since there is no implementation of do_stuff. However, gfortran compiles fine.
Hi Christian,
We think the code is correct so I’ve added a problem report, TPR#36816.
As a work around, it looks like you can add a 0 in the type bound procedure spot. Though gfortran will give an error.
module m
implicit none
private
type :: foo_t
integer :: x = 0
contains
end type foo_t
type(foo_t), parameter :: this_foo = foo_t(0,0)
interface
end interface
end module m
Hi Christian,
Engineering let me know that TPR#36816 was fixed in our 25.3 release.
% nvfortran -c test.F90 -V25.1
NVFORTRAN-F-0155-No default initialization in structure constructor- member do_stuff$tbp$1 (test.F90: 12)
NVFORTRAN/x86-64 Linux 25.1-0: compilation aborted
% nvfortran -c test.F90 -V25.3
-Mat
