Hi!
when i try to compile the following minimal example code:
module module1
implicit none
character(len=12), parameter, private :: dim_list(*) = [ &
'DIM_LON ', &
'DIM_LAT ', &
'DIM_LEV ', &
'DIM_TIME ', &
'DIM_XSTAGE ', &
'DIM_YSTAGE ', &
'DIM_ZSTAGE ', &
'DIM_SOILAY ']
end module
module module2
use module1
implicit none
integer, parameter, private :: my_parameter = 1
end module
program main
use module2
implicit none
write(*,*) "done!"
end program main
with:
nvfortran -c module1.f90
nvfortran -c module2.f90
nvfortran -c main.f90
I’m getting the following compiling error in the last step:
NVFORTRAN-F-0000-Internal compiler error. module:new_dtype, dt nfd 60 (main.f90: 3)
NVFORTRAN/x86-64 Linux 22.11-0: compilation aborted
Note that the following main program works (using module1
instead of module2
program main
use module1
implicit none
write(*,*) "done!"
end program main
It was tested it with different versions, including:
$ nvfortran --version
nvfortran 22.11-0 64-bit target on x86-64 Linux -tp haswell
NVIDIA Compilers and Tools
Copyright (c) 2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
The problem seems to be related to implied-shape arrays and nested modules… if I explicitly define the array shape (dim_list(8)
) in module1, the main program is compiled without errors (and it works)…
Could it be a compiler bug?
Thanks for your help
