nvfortran 22.3.0 on Ubuntu 20.04 fails to compile the following piece of code, which is standard-conforming.
! test_flang.f90
program test_flang
implicit none
integer, parameter :: m = 2
integer, parameter :: n = 100
integer, parameter :: k = 50
real :: x(m, n)
write (*, *) [x(:, k + 1:n), x(:, 1:k)]
end program test_flang
The error message looks like the following.
nvfortran --version && nvfortran test_flang.f90 && ./a.out
nvfortran 22.3-0 64-bit target on x86-64 Linux -tp haswell
NVIDIA Compilers and Tools
Copyright (c) 2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
NVFORTRAN-S-0152-All dimension specifiers must be ':' (test_flang.f90: 9)
0 inform, 0 warnings, 2 severes, 0 fatal for test_flang
This bug affects all the flang-based compilers, including the classic flang (7.0.1), Huawei Bisheng flang (Bisheng Compiler 1.3.3.b023), AOCC flang (AMD clang version 13.0.0), and nvfortran (22.3-0).
The bug has been reported to the classic flang developers, who seem to have fixed it.
Thank you for having a look at it.
