when trying to compile the following piece of code with nvfortran:
module c_data
implicit none
!----------Define Parameter--------------
type,public :: f
integer::f1
integer::f2
end type f
type (f),parameter::fk=f(1,2)
!---------------C-----------------------
TYPE, PUBLIC :: CTYPE
INTEGER :: D(3)
END TYPE CTYPE
TYPE (CTYPE) :: C
data C%D /fk%f1,2,3/
end module c_data
I get the following error message:
nvfortran -c test2.F90
NVFORTRAN-S-0034-Syntax error at or near % (test2.F90: 15)
0 inform, 0 warnings, 1 severes, 0 fatal for c_data
Is this a compiler bug? The code compiles with gfortran, ifort and ifx without any complains.
