Nvfortran compiler internal error (nvfortran 23.7)
compiling :
subroutine problem
use ISO_C_BINDING
implicit none
interface choix
subroutine choix1(machin)
import :: C_INTPTR_T, C_PTR, C_INT32_t
implicit none
integer(C_INTPTR_T), intent(IN) :: machin
end
subroutine choix2(machin)
implicit none
type(C_PTR), intent(IN) :: machin
end
end interface
type(C_PTR) :: cptr
integer(C_INT64_T) :: int64
call choix(transfer(int64,cptr))
end
result :
nvfortran -c problem3.F90
NVFORTRAN-S-0000-Internal compiler error. select_rtemp: bad ili 0 (problem3.F90: 18)
NVFORTRAN-S-0000-Internal compiler error. exp_call: ili ret type not cased 3 (problem3.F90: 18)
Hi mfvalin,
Thanks for the report. I was able to reproduce the error here and have filed TPR #34291. It appears to me to be an issue with using C_PTR in the transfer statement, but will have our engineers investigate.
-Mat
thank you for your quick answer,
i also reported the problem to AMD (4.1.0 aocc compilers)
as nvfortran’s cousin flang suffers from the same ailment
