Encountered errors compiling with nvfortran 21.1-0 :
NVFORTRAN-S-0000-Internal compiler error. mk_id: invalid symbol table index 0 (ice-20210224.F90: 9)
NVFORTRAN-S-0000-Internal compiler error. lower_sptr: bad sptr 0 (ice-20210224.F90: 14)
The following is a session log that includes a small reproducer for the error:
Script started on Wed 24 Feb 2021 04:51:26 PM MST
:: WARNING: setvars.sh has already been run. Skipping re-execution.
To force a re-execution of setvars.sh, use the '--force' option.
Using '--force' can result in excessive use of your environment variables.
$ pgf90 -V
pgf90 (aka nvfortran) 21.1-0 LLVM 64-bit target on x86-64 Linux -tp sandybridge
PGI Compilers and Tools
Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
$ cat ice-20210224.F90
module mod_x
implicit none
real,dimension(7), parameter :: lps = [-0.0065, 0.0, 0.001, 0.0028, 0.0, -0.0028, -0.002]
contains
subroutine sa
integer :: i
!real, dimension(7) :: tl
real :: tl
associate( ll => lps )
do i=2,7
tl=tl+ll(i-1)
end do
end associate
end subroutine sa
end module mod_x
$ pgf90 -c ice-20210224.F90
0 inform, 0 warnings, 2 severes, 0 fatal for sa
$ ifort -c ice-20210224.F90
$ exit
exit
Thank you,
John Michalakes
michalak@ucar.edu
