The following code causes the compiler (PGI18.10-1 64 bit on x86_64 Linux) to segfault:
module funcdefs
implicit none
contains
function nrOfAtoms() result(nAtom)
integer :: nAtom
nAtom = 3
end function nrOfAtoms
end module funcdefs
module dftbp_mmapi
use funcdefs, only : nrOfAtoms
implicit none
type :: TDftbPlus
contains
procedure :: nrOfAtoms => TDftbPlus_nrOfAtoms
end type TDftbPlus
contains
function TDftbPlus_nrOfAtoms(this) result(nAtom)
class(TDftbPlus), intent(in) :: this
integer :: nAtom
nAtom = nrOfAtoms()
end function TDftbPlus_nrOfAtoms
end module dftbp_mmapi
Running
pgfortran -c test.f90
results in
PGF90-S-0000-Internal compiler error. memsym_of_ast:unexp.ast 1 (test.f90: 32)
0 inform, 0 warnings, 1 severes, 0 fatal for tdftbplus_nrofatoms
Best regards, Bálint
