PGF90-F-0000-Internal compiler error. mk_mem_ptr_shape: no static desc for pointer
Is there a quick fix for this? PGI 7.0-2, x86
Hi Richard,
I see the same message in TPR#4353 which was fixed in the 7.1-5 compilers. However, Internal Compiler Errors (ICE) can be some what generic so this fix may or may not also fix your issue. The quickest thing to do is download the latest version of the compilers and see if it solves the problem.
If it does not, then please send a note to PGI support at trs@pgroup.com with an example of the code which causes the ICE. They will also determine if a work around is available,
Thanks,
Mat
