I got this error on the example below.
NVFORTRAN-F-0000-Internal compiler error. interf:new_symbol, symbol not found 625 (mod_test@smd_test.F90: 3)
NVFORTRAN/x86-64 Linux 21.7-0: compilation aborted
nvfortran -g -c mod_1.F90
nvfortran -g -c mod_1@smd_1.F90
nvfortran -g -c mod_2.F90
nvfortran -g -c mod_2@smd_2.F90
nvfortran -g -c mod_test.F90
nvfortran -g -c mod_test@smd_test.F90
mod_1.F90:
MODULE MOD_1
IMPLICIT NONE
INTERFACE PRC
MODULE PROCEDURE :: PRC_1
END INTERFACE PRC
INTERFACE
MODULE FUNCTION PRC_1(INPUT) RESULT(OUTPUT)
IMPLICIT NONE
REAL, INTENT(IN) :: INPUT
REAL :: OUTPUT
END FUNCTION PRC_1
END INTERFACE
END MODULE MOD_1
mod_1@smd_1.F90:
SUBMODULE(MOD_1) SMD_1
IMPLICIT NONE
CONTAINS
IMPLICIT NONE
REAL :: OUTPUT
OUTPUT = INPUT
END FUNCTION PRC_1
END SUBMODULE SMD_1
mod_2.F90:
MODULE MOD_2
IMPLICIT NONE
INTERFACE PRC
MODULE PROCEDURE :: PRC_2
END INTERFACE PRC
INTERFACE
MODULE FUNCTION PRC_2(INPUT) RESULT(OUTPUT)
IMPLICIT NONE
REAL :: OUTPUT
END FUNCTION PRC_2
END INTERFACE
END MODULE MOD_2
mod_2@smd_2.F90:
SUBMODULE(MOD_2) SMD_2
IMPLICIT NONE
CONTAINS
IMPLICIT NONE
REAL :: OUTPUT
OUTPUT = INPUT
END FUNCTION PRC_2
END SUBMODULE SMD_2
mod_test.F90
MODULE MOD_TEST
USE MOD_1
USE MOD_2
IMPLICIT NONE
INTERFACE
MODULE FUNCTION PRC_TEST(INPUT) RESULT(OUTPUT)
IMPLICIT NONE
REAL :: OUTPUT
END FUNCTION PRC_TEST
END INTERFACE
END MODULE MOD_TEST
SUBMODULE(MOD_TEST) SMD_TEST
IMPLICIT NONE
CONTAINS
IMPLICIT NONE
REAL :: OUTPUT
OUTPUT = INPUT
END SUBMODULE SMD_TEST
The problem disappears
- if
MOD_1andMOD_2are not used inMOD_TESTor - if the use statements in
MOD_TESTare moved inside theMODULE FUNCTION PRC_TESTor - if generic interfaces
PRCinMOD_1andMOD_2don’t have the same name.
