NVFORTRAN-S-0038-Symbol problem
I got this error on the following minimal example below with nvfortran 22.5:
NVFORTRAN-S-0038-Symbol, compute, has not been explicitly declared (mod_b.F90: 47)
  0 inform,   0 warnings,   1 severes, 0 fatal for prc_c
nvfortran -g -c -traceback mod_a.F90
nvfortran -g -c -traceback mod_b.F90
mod_a.F90:
MODULE MOD_A
   IMPLICIT NONE
   TYPE :: TYP_A
    CONTAINS
    PROCEDURE :: compute => PRC_A
   END TYPE TYP_A
CONTAINS
PURE SUBROUTINE PRC_A(A)
      IMPLICIT NONE
      CLASS(TYP_A), INTENT(INOUT) :: A
   END SUBROUTINE PRC_A
END MODULE MOD_A
mod_b.F90:
MODULE MOD_B
   USE MOD_A
   IMPLICIT NONE
   TYPE TYP_B
      TYPE(TYP_A) :: A
      CONTAINS
      PROCEDURE :: PRC_B
   END TYPE TYP_B
CONTAINS
PURE SUBROUTINE PRC_B(B)
      IMPLICIT NONE
      CLASS(TYP_B), INTENT(INOUT) :: B
      CALL PRC_C(B)
   END SUBROUTINE PRC_B
   PURE SUBROUTINE PRC_C(B)
      USE MOD_A
      IMPLICIT NONE
      INTEGER(KIND=4) :: m
      ! DO m = 1, 10 ! OK
      DO CONCURRENT (m = 1: 10)
         CALL B%A%compute
         ! CALL PRC_A(B%A) ! OK
      END DO
   END SUBROUTINE PRC_C
END MODULE MOD_B
The error will not arise, if I use :
  • DO instead of DO CONCURRENT or
  • CALL PRC_A(B%A) instead of CALL B%A%compute
I look forward to a fix of this bug. Thank you very much!
Ali
Hi Ali,
I don’t think this one is a bug, but rather that we don’t support procedure pointers in device code as of yet. We’re working on C++ virtual functions and function pointers now which should be then carried over to Fortran. Though, I added an RFE (TPR #31903) to track you request and I can then notify you when this support has been added.
-Mat
Thanks Mat!
Hi Ali,
FYI, TPR #31903 has been fixed in release 22.7.
I was incorrect in my original assessment in that this is type-bound procedure so should have work (i.e. it was a bug in the compiler). Engineering was able to resolve it and now the code will compile as expected.
-Mat
Many thanks. It works well.
