Nvfortran little bug report
I found a little compiler bug. If I compile the program below, I find the following errors:
NVFORTRAN-S-0186-Argument missing for formal argument & (submod.f90: 74)
NVFORTRAN-S-0186-Argument missing for formal argument & (submod.f90: 75)
  0 inform,   0 warnings,   2 severes, 0 fatal for totest
with
nvfortran --version
nvfortran 23.5-0 linuxarm64 target on aarch64 Linux -tp neoverse-n1
So if I uncomment the line with the reminder to use the withopt function in the submodule subfunc, it works
MODULE mod
   USE, intrinsic :: iso_fortran_env, only : ip => INT32, rp => REAL64
   implicit none
   integer(ip), parameter :: lp = 4
   INTERFACE
      MODULE FUNCTION withopt( arg , default ) RESULT( opt )
         logical(lp), intent(in), optional :: default
         logical(lp), intent(in), optional :: arg
         logical(lp)                       :: opt
      END FUNCTION withopt
   END INTERFACE
END MODULE mod
SUBMODULE (mod) submod
   implicit none
CONTAINS
      logical(lp)                       :: opt
      opt = .false.
      if( present( default ) ) opt = default
      if( present( arg     ) ) opt = arg
END SUBMODULE submod
MODULE func
   USE mod, only : ip , rp , lp , withopt
   implicit none
   INTERFACE
      MODULE SUBROUTINE totest( opt )
         logical(lp), intent(in), optional :: opt
      END SUBROUTINE totest
   END INTERFACE
END MODULE func
SUBMODULE (func) subfunc
   ! USE mod, only : withopt
   implicit none
CONTAINS
      if (       withopt( opt ) ) write(6,*) 'true'
      if ( .not. withopt( opt ) ) write(6,*) 'false'
END SUBMODULE subfunc
PROGRAM test
   USE func, only : totest
   call totest( opt=.true.  )
   call totest( opt=.false. )
END PROGRAM test
Thanks for the report fcouderc!
I’ve filed a problem report, TPR #33923, and sent to engineering for review.
-Mat
FYI, TPR #33923 should be fixed in our 24.1 release.
% nvfortran -V23.11 -c test.F90
NVFORTRAN-S-0186-Argument missing for formal argument & (test.F90: 76)
NVFORTRAN-S-0186-Argument missing for formal argument & (test.F90: 77)
% nvfortran -V24.1 -c test.F90
