Nvfortran error with submodules
Hello, I have encountered an error while using submodules with nvfortran. I wrote the following MWE.
MODULE m1
    implicit none
    INTERFACE
        MODULE PURE FUNCTION getlen( string ) result( out )
            character(len=*), intent(in) :: string
            integer :: out
        END FUNCTION getlen
        MODULE SUBROUTINE print_hello
        END SUBROUTINE print_hello
    END INTERFACE
END MODULE
MODULE m2
    USE m1, only : getlen
    implicit none
    character(len=5), parameter :: hello = "hello"
    CONTAINS
        SUBROUTINE foo
            write(*, *) getlen("test")
        END SUBROUTINE
END MODULE
SUBMODULE (m1) sub_m1
    USE m2, only : hello
    implicit none
    CONTAINS
            integer :: out
            out = len(trim(string))
        END FUNCTION getlen
            write(*, *) getlen( hello )
END SUBMODULE sub_m1
PROGRAM Test
    USE m1, only : print_hello
    implicit none
    call print_hello()
END PROGRAM Test
Using nvfortran 23.3 or 23.9, I got the error:
NVFORTRAN-S-0038-Symbol, out, has not been explicitly declared (test.f90)
I’m not sure if it’s a compiler bug or not. It compiles fine with gfortran.
Hi bfabreges,
It’s a compiler issue and appears similar to other reports we’ve had. I filed TPR#34527 and sent it to engineering to investigate.
Mat
FYI, TPR #34527 should be fixed in our 24.1 release:
% nvfortran -V24.1 -c test_subm.f90
