For “nvfortran” (including version 22.9), there seems to be a bug when select type is used within a submodule. Here is a minimal example that is important for several programs and libraries including h5fortran.
This bug has been present I think since beginning of nvfortran Fortran 2008 support.
module amod
use, intrinsic :: iso_fortran_env
implicit none
interface
module subroutine sel(A)
CLASS(*), INTENT(INOUT) :: A
end subroutine sel
end interface
end module amod
submodule (amod) smod
implicit none
contains
class(*), intent(inout) :: A
select type (A)
type is (real(real32))
print *, 'real32'
type is (real(real64))
print *, 'real64'
type is (integer(int32))
print *, 'int32'
class default
error stop 'unknown type'
end select
end subroutine sel
end submodule smod
program aaaa
use amod
implicit none
real(real32) :: x
real(real64) :: x64
call sel(x)
call sel(x64)
end program
compling with nvfortran gives errors:
/tmp/nvfortrangTv3eskus9U3F.o: In function `amod_sel_':
src.f90:25: undefined reference to `amod__smod_sel__f03_unl_poly_0____td2_'
Note the more common “procedure” syntax in this example has a different but related error. Either of these syntaxes is legal Fortran 2008. This syntax below is more common I believe.
module amod
implicit none
interface
end subroutine sel
end interface
end module amod
implicit none
contains
module procedure sel
select type (A)
print *, 'real32'
print *, 'real64'
print *, 'int32'
class default
end select
end procedure sel
end submodule smod
program aaaa
use amod
implicit none
real(real32) :: x
real(real64) :: x64
call sel(x)
call sel(x64)
end program
NVFORTRAN-S-0155-A SELECT TYPE selector without an associate-name must be a named variable (y.f90: 24)
NVFORTRAN-S-0000-Internal compiler error. mk_id: invalid symbol table index 0 (y.f90: 25)
NVFORTRAN-S-0000-Internal compiler error. sym_of_ast: unexpected ast 76 (y.f90: 25)
NVFORTRAN-S-0000-Internal compiler error. mk_id: invalid symbol table index 0 (y.f90: 27)
NVFORTRAN-S-0000-Internal compiler error. sym_of_ast: unexpected ast 77 (y.f90: 27)
NVFORTRAN-S-0000-Internal compiler error. mk_id: invalid symbol table index 0 (y.f90: 29)
NVFORTRAN-S-0000-Internal compiler error. sym_of_ast: unexpected ast 77 (y.f90: 29)
NVFORTRAN-S-0000-Internal compiler error. mk_id: invalid symbol table index 0 (y.f90: 33)
0 inform, 0 warnings, 14 severes, 0 fatal for sel
Thanks for the report mhirsch!
I was able to recreate both errors here, and have filed two issue reports. TPR#32551 for the undefined references error, and TPR#32552 for the ICE.
-Mat
I have the same symptoms with nvfortran 22.11, so I think the bug wasn’t gotten to yet.
Still same symptoms with nvfortran 23.1
Hi mhirsch,
The first issue with the undefined references, TPR #32551, was fixed in our 23.1 release.
-Mat
Thanks Mat, I also observe with nvfortran 23.3 that TPR #32551 is a good fix, and that TPR #32552 is still broken.
With nvfortran 24.1 TPR #32552 is still broken
Hi mhirsch,
TPR#32552 has been fixed in our 24.9 release.
-Mat
