Next bug, again with submodules. This one appears to be a related to the use of the optional and target attributes for an allocatable intent(out) array for a derived type.
The following code results in a compile error:
module tecplotIOMod
implicit none
type tecZoneType
integer :: type
end type tecZoneType
interface
module subroutine readTecFE(outZones)
type(tecZoneType), dimension(:), allocatable, intent(out), optional, target :: outZones
end subroutine readTecFE
end interface
end module tecplotIOMod
submodule(tecplotIOMod) tecplotIOSubMod
implicit none
contains
end submodule tecplotIOSubMod
program main
use tecplotIOMod
print *,'Hello World'
end program main
The definition of outZones is exactly the same between the module and submodule definitions, but I still get the compile error:
NVFORTRAN-S-1058-The type of definition argument outzones does not match its declaration type (main.F90: 18)
0 inform, 0 warnings, 1 severes, 0 fatal for readtecfe
It will compile if remove target attribute. I was able to refactor the code remove the need for target attribute.
Thanks,
Gaetan
