Undeclared allocate fails with ICE
Hi all,
the following code example is erroneous, so that the compiler should quit with a corresponding message. Instead, it fails with an internal compiler error (nvfortran 23.3-0):
module test
   type t1
      integer :: x
   end type t1
   type t2
      type(t1), allocatable :: y(:)
   end type t2
   contains
  subroutine do_stuff()
      allocate (y(1))
      !!!allocate (x(1)) -> Invalid type-spec found in ALLOCATE statement
   end subroutine do_stuff
end module test
The error message is
NVFORTRAN-S-0000-Internal compiler error. check_member: cannot match member with derived type     629  (test.F90: 15)
Note that if the variable y is replaced by another one which does not appear in type t2, e.g. x, the compiler instead fails normally with Invalid type-spec found in ALLOCATE statement.
Thanks for the report Christian. I reproduced the issue here and have reported it as TPR #33666.
-Mat
