Allocatable arrays made private for openmp leads to out of bounds (0x0) writes with nvfortran
I’m trying add openmp offload to a code with many scratch arrays but making them private doesn’t work properly.
Here is a reproduction of what I mean:
PROGRAM scratchTest
USE OMP_LIB
IMPLICIT NONE
INTEGER, PARAMETER  :: NN=4096
INTEGER, PARAMETER  :: NM=4096
INTEGER, PARAMETER  :: SCRATCHSIZE=10
REAL,ALLOCATABLE,DIMENSION(:,:) :: scratch
REAL,ALLOCATABLE,DIMENSION(:,:)   :: A
REAL :: st, et
INTEGER::I,J,K
ALLOCATE(A(NN,NM))
ALLOCATE(scratch(SCRATCHSIZE,SCRATCHSIZE))
A = 0.0D0
scratch = 0.0D0
st = omp_get_wtime()
!$OMP target enter data map(to:A)
    !$OMP target teams distribute parallel do private(scratch) collapse(2)
    DO j=1,NN
        DO i=1,NM
            DO k=1,SCRATCHSIZE
                    scratch(k,k)=j+i
            END DO
            A(i,j)=SUM(scratch)
        END DO
    END DO
    !$OMP END target teams distribute parallel do
!$OMP target exit data map(from:A)
et = omp_get_wtime()
PRINT *, " total time: ", (et - st), " s"
PRINT *,A(10,10)
END PROGRAM scratchTest
(This code doesn’t do anything useful. It just illustrates the problem.)
If I change scratch to be declared with a certain size at compile time it works fine but with allocatable it just crashes like this:
========= Invalid global write of size 8 bytes
========= at nvkernel_MAIN__F1L27_2_+0xaf0 in /home/ec2-user/private_problem/scratch_array.f90:31
========= by thread (56,0,0) in block (7,0,0)
========= Address 0x0 is out of bounds
========= and is 8,696,889,344 bytes before the nearest allocation at 0x206600000 of size 8,388,864 bytes
========= Saved host backtrace up to driver entry point at kernel launch time
========= Host Frame: [0x33137f]
========= in /lib64/libcuda.so.1
========= Host Frame:launchInternal in platform_cuda/hxCuda.c:3402 [0x4ac4c]
========= in /opt/nvidia/hpc_sdk/Linux_x86_64/24.5/compilers/lib/libnvomp.so
…(etc)
Is making an allocatable array private in nvfortran with openmp offload not possible or am I missing something?
Yes, it’s possible, though with “distribute parallel do” private allocatable arrays need to be allocated on the device. Hence you’re likely encountering a heap overflow given the default device heap is small.
You have a few options:
  1. Set the environment variable NV_ACC_CUDA_HEAPSIZE to a large value (I used 1GB)
  2. Explicitly call the CUDA Fortran routine “cudaDeviceSetLimit” with “cudaLimitMallocHeapSize” and a large value. Note NV_ACC_CUDA_HEAPSIZE basically just calls this for you though applied it to all kernel launches. Calling it yourself allows to the change between kernels.
  3. Switch to using the “loop” construct instead of “distribute parallel do”. With “loop”, the compiler doesn’t need to outline the region and therefor can allocate the private arrays before launching the kernels rather than in the kernel.
Thank you for the prompt reply.
I can confirm that those options work for my reproduction example.
However in the real code I don’t think I can set the heapsize high enough to make it work so perhaps I have too much to allocate and not enough memory.
Changing the “distribute parallel do” to the “loop” construct works perfectly in my simplified reproduction example but in the real code if I change to the “loop” construct the compiler crashes with a segfault.
Possible, if so, you may need to not collapse the loops or possibly investigate a blocking algorithm where only a portion of NN and NM are computed.
Are you able to provide a reproducing example? If so, I can report the issue to engineering so we can get it fixed.
Another possibility is to switch to using OpenACC “parallel” which is similar to OpenMP’s “loop” construct.
I’m still working on finding a simple repro of the compiler segfault.
However, in the process I’ve come across another problem which is going to cause me headaches.
It seems that global variables can’t be made private successfully.
MODULE SUMTEST
IMPLICIT NONE
!$OMP declare target(scratch,A)
END MODULE SUMTEST
PROGRAM scratchTest
    USE OMP_LIB
    USE SUMTEST
    IMPLICIT NONE
    INTEGER, PARAMETER  :: NN=512
    INTEGER, PARAMETER  :: NM=512
    REAL :: st, et
    INTEGER::I,J,K
    ALLOCATE(A(NN,NM))
    A = 0.0D0
    scratch = 0.0D0
    !$OMP target enter data map(to:A,scratch)
    !$OMP target teams loop private(scratch) collapse(2)
    DO j=1,NN
        DO i=1,NM
                scratch(1,1)=j+i
                A(i,j)=scratch(1,1)
        END DO
    END DO
    !$OMP END target teams loop
    PRINT *,A(10,10)
This code prints random numbers at the end. It seems due to all threads writing to a single scratch array.
The original code prints the correct value of 200 and the end.
Also the with the loop directive I don’t seem to be able to pass a private array to a subroutine:
MODULE SUMTEST
IMPLICIT NONE
CONTAINS
SUBROUTINE SUM_SCRATCH(i,j,Ap,scratchp)
        IMPLICIT NONE
        INTEGER, INTENT(IN) :: i,j
        REAL,DIMENSION(:,:), INTENT(IN) :: scratchp
        REAL,DIMENSION(:,:), INTENT(INOUT)   :: Ap
        Ap(i,j)=SUM(scratchp)
END SUBROUTINE SUM_SCRATCH
END MODULE SUMTEST
PROGRAM scratchTest
    USE OMP_LIB
    USE SUMTEST
    IMPLICIT NONE
    REAL :: st, et
    INTEGER::I,J,K
    ALLOCATE(A(NN,NM))
    A = 0.0D0
    scratch = 0.0D0
    !$OMP target enter data map(to:A, scratch)
    !$OMP target loop private(scratch) collapse(2)
        DO j=1,NN
            DO i=1,NM
                DO k=1,SCRATCHSIZE
                        scratch(k,k)=j+i
                END DO
                call SUM_SCRATCH(i,j,A,scratch)
            END DO
        END DO
        !$OMP END target loop
    PRINT *,A(10,10)
NVFORTRAN-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): No device symbol for address reference (scratch_array2.f90: 47)
If I remove private(scratch) it compiles but of course the results are incorrect.
Correct, a variable can’t be both global and private since the compiler has no way of knowing which one you want. In this case, it’s using the global copy. To fix your code, remove “scratch” from the “declare target” and “enter data” directives.
You can, though we have a known limitation on passing private assumed shape arrays as arguments. The work around is to use:
call SUM_SCRATCH(i,j,A,scratch(:,:))
The issue is that in order to pass an assumed shape array, the descriptor is passed, but a private array doesn’t have a descriptor (it’s one block of memory partitioned between the threads). Using the slicing expression will create a descriptor at runtime as part of the call so it can then be passed.
It works with “distribute parallel do” since the private array is allocated separately by each thread on the device. So that’s another work around, but you’ll then need to contend with the original heap overflow problem.
Right. Yes both those fixes work for me.
In the actual code it may require the adding of some slicing expressions to subroutine calls.
I also now have a very simple repro of the crash during compiling:
MODULE GLOBALS
   IMPLICIT NONE
   REAL :: Z
   REAL, ALLOCATABLE, DIMENSION(:)::A
END MODULE GLOBALS
MODULE RECON
   USE GLOBALS
   IMPLICIT NONE
CONTAINS
   SUBROUTINE CRASH_REPRO()
      IMPLICIT NONE
      INTEGER::II
      ALLOCATE (A(10))
      Z = 7
      DO II = 1, 10000;
         A = Z;
      END DO
      !$OMP end target teams loop
      PRINT *, A(1)
   END SUBROUTINE CRASH_REPRO
END MODULE RECON
PROGRAM compilerCrashTest
   USE RECON
   IMPLICIT NONE
   CALL CRASH_REPRO()
END PROGRAM compilerCrashTest
The compiler crash is resolved by adding
!$OMP declare target(A)
(And with enter/exit to/from data transfer of A the output is as expected)
but just having the compiler seqfault isn’t very helpful in finding the offending variable.
Thanks! I created a problem report, TPR #35799, and sent it to engineering to investigate.
Another work around is to use slicing:
      DO II = 1, 10000;
         A(:) = Z;
      END DO
Thanks @MatColgrove
Now I’ll go try to apply all these bits of information to the real code and see if I can get it working.
Parsing an array to a subroutine without slice expression within loop construct also causes the compiler to segfault:
MODULE GLOBALS
   IMPLICIT NONE
   CONTAINS
SUBROUTINE CRASH_TEST(Ap)
    IMPLICIT NONE
    REAL,DIMENSION(:), INTENT(INOUT)   :: Ap
    Ap(2)=10
END SUBROUTINE CRASH_TEST
END MODULE GLOBALS
   USE GLOBALS
   IMPLICIT NONE
   IMPLICIT NONE
   INTEGER::II
   ALLOCATE (A(10))
   DO II = 1, 10000;
      CALL CRASH_TEST(A)
   END DO
   PRINT *, A(1)
Probably the same root cause as the assignment operator crash.
Given the previous dissuasion i suppose there isn’t a way (with openmp directives) to deal with the situation of a global made private for the target loop but also referenced in a subroutine called within that loop.
E.g.
MODULE SUMTEST
IMPLICIT NONE
CONTAINS
SUBROUTINE SUM_SCRATCH(i,j,Ap)
    IMPLICIT NONE
    Ap(i,j)=SUM(scratch)
END MODULE SUMTEST
PROGRAM scratchTest
    USE OMP_LIB
    USE SUMTEST
    IMPLICIT NONE
    REAL :: st, et
    INTEGER::I,J,K
    ALLOCATE(A(NN,NM))
    A = 0.0D0
    scratch = 0.0D0
    DO j=1,NN
        DO i=1,NM
            DO k=1,SCRATCHSIZE
                scratch(k,k)=j+i
            END DO
            call SUM_SCRATCH(i,j,A)
        END DO
    END DO
    PRINT *,A(10,10)
Seems like only way would be to change the way the code actually allocates and/or passes the variables.
When targeting the CPU, I believe you’d use a “threadprivate” directive on the module variable. However, we were not able to implement the same functionality for device code.
Besides passing in the private array, another possibility is to manually privatize the array by adding two extra dimensions, size with NN and NM. The array itself would be global but each thread would have a unique scratch space.
If you don’t mind adding a bit of CUDA Fortran, you can add the “device” attribute to the array so that it’s only created on the device.
Yes, I thought that might be the answer.
You have hit the nail on the head. The code I’m working has been previously decorated with openmp targeting cpu and threadprivate was used to make all the global scratch arrays private to each thread but that can’t quite be replicated in the same way for gpu offload.
We’ll have to think about how we want to approach that problem.
While continuing to modify this code this code. I ran across another compiler crash:
MODULE GLOBALS
IMPLICIT NONE
REAL :: scratchA
CONTAINS
SUBROUTINE SCRATCH_TEST(A)
    IMPLICIT NONE
    REAL, INTENT(INOUT)::A
    A = 7
END SUBROUTINE SCRATCH_TEST
END MODULE GLOBALS
PROGRAM scratchTest
    USE OMP_LIB
    USE GLOBALS
    IMPLICIT NONE
    INTEGER j
    DO j=1,10000
            call SCRATCH_TEST(scratchA)
    END DO
Rather than complaining that scratchA needs ‘omp target declare’ the compiler segfaults
Thanks siensinnes. It looks to be the same error, just under a different scenario, as #35799 since the compiler is seg faulting in the same spot. I’ve added this example to the report.
