allocation problem in cuFFT
Dear all:
I try to check maximum problem size of cuFFT on 3D data.
my platform: winxp pro64, vc2005, GTX295 + Tesla C1060, driver 109.38, cuda 2.3
I use Tesla C1060 as computational kernel and focus on “double precision”
first I can allocate 3.7GB to do FFT (real to complex) as code 1
nx = ny = nz = 628
code 1
[codebox]
cufftResult ret ;
size_t nx = 628 ;
size_t ny = 628 ;
size_t nz = 628 ;
size_t N  = nx * ny * nz ;
double    *d_u ;	 // device of source
double    *d_u_hat ; // device of frequency component of source
cufftHandle   plan ;  // plane of forward R2C transform
cutilSafeCall( cudaMalloc((void**)&d_u,     sizeof(double)*N) );
cutilSafeCall( cudaMalloc((void**)&d_u_hat, sizeof(double)*N) );
ret = cufftPlan3d(&plan, nx, ny, nz, CUFFT_D2Z );
if ( CUFFT_SUCCESS != ret ){
if ( CUFFT_ALLOC_FAILED == ret ){
    cout << "Error: Allocation of GPU resources for the plan failed" << endl ;
}else{
    cout << "Error: cufftPlan3d fails for other reason" << endl ;
}else{
cout << "cufftPlan3d success" << endl ;
} // if (CUFFT_SUCCESS != ret )
[/codebox]
Second if I want to do the same FFT for 2 data set but small size
nx = ny = nz = 480, then error occurs at
with error ID = CUFFT_ALLOC_FAILED (see code 2)
code 2
[codebox]
cufftResult ret ;
size_t nx = 240*2 ;
size_t ny = 240*2 ;
size_t nz = 240*2 ;
double *d_G_hat ; // device of frequency component of kernel
double *d_G ; // d_G <–> h_G
cutilSafeCall( cudaMalloc((void**)&d_G_hat, sizeof(double)*N) );
cutilSafeCall( cudaMalloc((void**)&d_G, sizeof(double)*N) );
}else{
}else{
cout << “cufftPlan3d success” << endl ;
} // if (CUFFT_SUCCESS != ret)
[/codebox]
moreover if I interchange
and
it says “out of memory” (see code 3)
code 3
[codebox]
cufftResult ret ;
size_t nx = 240*2 ;
size_t ny = 240*2 ;
size_t nz = 240*2 ;
}else{
}else{
} // if ( CUFFT_SUCCESS != ret )
[/codebox]
However above code only uses 3.3GB, smaller than 3.7GB in code 1.
I cannot understand why “out of memory” occurs.
Dear all:
I test code 2 with “single precision”, then
I can allocate 3.78GB (nx = ny = nz = 314*2 ), this is large than that in
“double precision” which only has 3.29GB ( nx = ny = nz = 238*2 )
Does anyone know why?
dear all:
I use runtme API cuMemGetInfo() to extract memory usage and have some explanation for my question
Generally speaking, I add cuMemGetInfo() to sample memory usage before cufftPlan3d() and after cufftPlan3d(),
then watch how large device memory does cufftPlan3d() need?
I think that cufftPlan3d() needs extra global memory as working space, the reason comes from CUFFT_Library_2.3.pdf
page 13, Accuracy and Performance
The CUFFT library implements several FFT algorithms, each having
different performance and accuracy. The best performance paths
correspond to transform sizes that meet two criteria:
  1. Fit in CUDA?s shared memory
  2. Are powers of a single factor (for example, powers of two)
For transform sizes that do not meet either criteria above, CUFFT uses
an out-of-place, mixed-radix algorithm that stores all intermediate
results in CUDA’s global GPU memory.
first I modify code 3 as
[codebox] size_t nx = 2402 ; size_t ny = 2402 ; size_t nz = 240*2 ;
double    *d_G ;     // d_G <--> h_G
unsigned int free_mem,total_mem, used_mem;
cuMemGetInfo( &free_mem, &total_mem );
used_mem = total_mem-free_mem;
printf("before plan3d:total mem: %0.3f MB, free: %0.3f MB, used : %0.3f MB\n",
	((double)total_mem)/1024.0/1024.0, ((double)free_mem )/1024.0/1024.0,
	((double)used_mem )/1024.0/1024.0 );
cufftResult ret = cufftPlan3d(&plan, nx, ny, nz, CUFFT_D2Z );
printf("after plan3d:total mem: %0.3f MB, free: %0.3f MB, used : %0.3f MB\n",
cutilSafeCall( cudaMalloc((void**)&d_G,     sizeof(double)*N) );	[/codebox]
The error message is
[codebox]before plan3d:total mem: 4095.750 MB, free: 1518.188 MB, used : 2577.563 MB
after plan3d:total mem: 4095.750 MB, free: 672.672 MB, used : 3423.078 MB
cudaSafeCall() Runtime API error in file <method3.cpp>, line 64 : out of memory.[/codebox]
this means taht cufftPlan3d() asks 343.078 - 2577.563 = 845MB global memory, then
next statement “cudaMalloc((void**)&d_G, sizeof(double)*N)” fails.
here nx = ny = nz = 240*2 = 2^5 x 3 x 5 is not power of single factor, so cufftPlan3d()
needs extrac memory to do out-of-place work.
second, I modify code 2 again
	((double)total_mem)/1024.0/1024.0,((double)free_mem )/1024.0/1024.0,
}[/codebox]
the error message is
[codebox]before plan3d:total mem: 4095.750 MB, free: 674.438 MB, used : 3421.313 MB
after plan3d:total mem: 4095.750 MB, free: 674.438 MB, used : 3421.313 MB
Error: Allocation of GPU resources for the plan failed[/codebox]
It seems that cufftPlan3d() does not ask any extra memory, this is wrong since
from code 3, we know cufftPlan3d() needs 845MB extra memory. however cufftPlan3d()
cannot allocate such working space since 3421.313 + 845 ~ 4.167GB (out-of-memory),
hence it returns “CUFFT_ALLOC_FAILED”
finally we modify code 1
[codebox] size_t nx = 628 ; size_t ny = 628 ; size_t nz = 628 ;
	((double)used_mem )/1024.0/1024.0 ); [/codebox]
output message is
[codebox]before plan3d:total mem: 4095.750 MB, free: 270.215 MB, used : 3825.535 MB
after plan3d:total mem: 4095.750 MB, free: 222.043 MB, used : 3873.707 MB[/codebox]
cufftPlan3d() only asks 3873.707 - 3825.535 = 48.2 MB, and total memory is 3873.7MB < 4GB,
hence it works without any error.
Question: I can understand that cufftPlan3d() needs extra memory for data size is not power of
single factor, however I cannot understand why
  1. n = 480 = 2^5 x 3 x 5, cufftPlan3d() needs 845MB
  2. n = 628 = 4 x 157, cufftPlan3d() only needs 48.2MB
ps: if I use nx=ny=nz= 238*2, then cufftPlan3d() needs 194MB extra memory, it seems that
size of working space has large variation.
