size limit of 1D FFT
Dear all: I want to do 3-dimensional sine FFT via cuFFT,
the procedure is
  1. compute 1-D FFT for dimension z with batch = n1*n2
2 transpose from (x,y,z) to (y,z,x)
  1. compute 1-D FFT for dimension x with batch = n2*n3
  2. transpose from (y,z,x) to (z,x,y)
  3. compute 1-D FFT for dimension y with batch = n1*n3
  4. transpose from (z,x,y) to (x,y,z)
everything is O.K. but I suffer problem on (nx,ny,nz) = (512,512,512)
the problem comes from 1-D FFT, I write simple code to demonstrate this
the following code is doing 1-D FFT R2C with size n * batch
trnasform real d_u (of size batch * n) to complex d_u_hat ( of size batch*(n/2+1) )
[codebox]#include <stdio.h>
#include <assert.h>
#include “global.h”
void randomInit(doublereal* data, unsigned long long int size)
for (int i = 0; i < size; ++i){ data[i] = (double)rand() / (double)RAND_MAX; }
void test_1D_size_limit( void )
#ifdef DO_DOUBLE
int batch = 512 * 512  ;
int n = 256*2 ;
#else
int n = 511*2 ;
#endif
cufftResult flag ;
cufftHandle  plan ;
doublereal *d_u ; // device memory
Complex *d_u_hat ; // device memory
doublereal *u ; // host memory
// step 1: random data
u = (doublereal *)malloc( sizeof(doublereal)*batch*n ) ;
assert( u ) ;
randomInit( u,  batch*n ) ; // random data
// step 2: out-of-place forward FFT in device
cutilSafeCall( cudaMalloc((void**)&d_u, sizeof(doublereal)*batch*n) );
CUDA_SAFE_CALL(cudaMemcpy( d_u, u, sizeof(doublereal)*batch*n , cudaMemcpyHostToDevice) );
cutilSafeCall( cudaMalloc((void**)&d_u_hat, sizeof(Complex)*batch*((n>>1) + 1) ) );
#if defined (DO_DOUBLE)
flag = cufftPlan1d(&plan, n, CUFFT_D2Z, batch );
if ( CUFFT_SUCCESS != flag ){printf("Error: cufftPlan1d( CUFFT_D2Z ) fails\n"); }
#else
flag = cufftPlan1d(&plan, n, CUFFT_R2C, batch );
if ( CUFFT_SUCCESS != flag ){ printf("Error: cufftPlan1d( CUFFT_R2C ) fails\n"); }
#endif
flag = cufftExecD2Z( plan, (cufftDoubleReal *)d_u, d_u_hat );
#else
flag = cufftExecR2C( plan,       (cufftReal *)d_u, d_u_hat );
#endif
	printf("Error (cufftExecR2C): %s \n",cudaGetErrorString (cudaGetLastError()));
	printf("error code (cufft) = %d\n", flag);
[/codebox]
the content of file “global.h” is
[codebox]// “global.h”
#include <cufft.h>
#include <cutil_inline.h>
//#define DO_DOUBLE
#ifdef DO_DOUBLE
typedef double  doublereal ;
typedef cufftDoubleComplex Complex;
#else
typedef float   doublereal ;
typedef cufftComplex  Complex;
#endif[/codebox]
  1. batch = 512 * 512, n = 511*2
    the program is O.K.
  2. batch = 512 * 512, n = 512*2
output is
Error (cufftExecR2C): memory size or pointer value too large to fit in 32 bit
error code (cufft) = 6
after searching cufft.h, error code = 6 means “CUFFT_EXEC_FAILED”
so this is not out-of-memory problem,
does this mean that maximum size of 1-D FFT R2C is 512512511*2, which leads to
2GB ( du + du_hat )
ps: my platform is winxp pro64, vc2005, Tesla C1060, driver 190.38, cuda 2.3
sorry, I must correct my testing code,
I use cudaGetErrorString (cudaGetLastError()) to find out error message,
[codebox]// step 1: random generate data
assert( u ) ;
else
endif
cudaThreadSynchronize();
printf("Error( cufftPlan1d ): %s \n",cudaGetErrorString (cudaGetLastError()));
else
endif
printf("Error(cufftExecR2C): %s \n",cudaGetErrorString (cudaGetLastError()));
[/codebox]
if batch = 256 * 256, n = 128 ,then error occurs
output is
Error( cufftPlan1d ): no error
Error(cufftExecR2C): invalid configuration argument
(1) if I try (batch,n) = (256*255, 128), then no error.
This may imply that “1D transform sizes up to 8 million elements”
however if I try (batch,n) = (1, 256* 256 * 128), then no error.
I am confused.
(2) when error “invalid configuration argument” occurs,
why cufftExecR2C return “CUFFT_SUCCESS” such that code segment
does not show any error?
Can anyone repeat my error?
dear all: I write another code to test size limit of 1-D FFT
Given (n1, n2, n3)
  1. compute FFT along z-axis with size 2*(n3+1), batch = n1*n2
  2. compute FFT along x-axis with size 2*(n1+1), batch = n2*n3
  3. compute FFT along y-axis with size 2*(n2+1), batch = n3*n1
after each cufftExecR2C call, we use cudaGetErrorString (cudaGetLastError())
to report its error message.
source is
[codebox]ifdef DO_DOUBLE
int n1 = 512 ;
int n2 = 512 ;
int n3 = 383 ;
else
int n1 = 511 ;
int n2 = 511 ;
int n3 = 768 ;
endif
cufftResult  flag ;
cufftHandle  plan_z, plan_x, plan_y ;
int  NN = n1*n2 ;
NN = qMax( NN, n2*n3 ) ;
NN = qMax( NN, n3*n1 ) ; // NN = max( n1, n2, n3)
size_t numOfElement = n1*n2*n3 + 2*NN ;
u = (doublereal *)malloc( sizeof(doublereal)*numOfElement ) ;
assert( u ) ;
randomInit( u,  numOfElement ) ;
cutilSafeCall( cudaMalloc((void**)&d_u, sizeof(doublereal)*numOfElement) );
CUDA_SAFE_CALL(cudaMemcpy( d_u, u, sizeof(doublereal)*numOfElement , cudaMemcpyHostToDevice) );
cutilSafeCall( cudaMalloc((void**)&d_u_hat, sizeof(Complex)*numOfElement) );
cufftPlan1d(&plan_z, 2*(n3+1), CUFFT_D2Z, n1*n2 );
cufftPlan1d(&plan_x, 2*(n1+1), CUFFT_D2Z, n2*n3 );
cufftPlan1d(&plan_y, 2*(n2+1), CUFFT_D2Z, n3*n1 );
else
cufftPlan1d(&plan_z, 2*(n3+1), CUFFT_R2C, n1*n2 );
cufftPlan1d(&plan_x, 2*(n1+1), CUFFT_R2C, n2*n3 );
cufftPlan1d(&plan_y, 2*(n2+1), CUFFT_R2C, n3*n1 );
endif
[/codebox]
code is so long that I divide it into two parts
[codebox]// z-FFT
flag = cufftExecD2Z( plan_z, (cufftDoubleReal *)d_u, d_u_hat );
else
flag = cufftExecR2C( plan_z,       (cufftReal *)d_u, d_u_hat );
endif
printf("Error(cufft, z-axis): %s \n",cudaGetErrorString (cudaGetLastError()));
if ( CUFFT_SUCCESS != flag ){ printf("error code (cufft) = %d\n", flag); }
// x-axis FFT
flag = cufftExecD2Z( plan_x, (cufftDoubleReal *)d_u, d_u_hat );
else
flag = cufftExecR2C( plan_x,       (cufftReal *)d_u, d_u_hat );
endif
printf("Error(cufft, x-axis): %s \n",cudaGetErrorString (cudaGetLastError()));
// y-axis FFT
flag = cufftExecD2Z( plan_y, (cufftDoubleReal *)d_u, d_u_hat );
else
flag = cufftExecR2C( plan_y,       (cufftReal *)d_u, d_u_hat );
endif
printf("Error(cufft, y-axis): %s \n",cudaGetErrorString (cudaGetLastError()));
if ( CUFFT_SUCCESS != flag ){ printf("error code (cufft) = %d\n", flag); }		[/codebox]
platform: winxp pro64, vc2005, Tesla C1060, driver 190.38, cuda2.3
we consider “float” version and output is summaried as following table
(1) size: total device memory
(2) z-FFT: error message after z-FFT
(3) x-FFT: error message after x-FFT
(4) y-FFT: error message after y-FFT
[codebox]--------------±--------±-----------------------±-----------------------±-----------------------+
n1,n2,n3 | size | z-FFT | x-FFT | y-FFT |
255,255,255 | 255 MB | no error | no error | no error |
511,255,255 | 511 MB | invalid configuration | no error | invalid configuration |
          |         | argument               |                        | argument               |
512,256,256 | 516 MB | no error | no error | no error |
511,511,255 | 1024 MB | invalid configuration | invalid configuration | out of memory |
          |         | argument               | argument               | CUFFT_EXEC_FAILED      |
512,512,256 | 1032 MB | no error | no error | no error |
511,511,511 | 2044 MB | out of memory | out of memory | out of memory |
          |         | CUFFT_EXEC_FAILED      | CUFFT_EXEC_FAILED      | CUFFT_EXEC_FAILED      |
512,512,512 | 2056 MB | no error | no error | no error |
512,511,767 | 3074 MB | no error | no error | memory size or pointer |
          |         |                        |                        | value too large to fit |
          |         |                        |                        | in 32 bit              |
512,512,767 | 3080 MB | no error | no error | no error |
512,512,768 | 3084 MB | no error | no error | no error |
512,512,1024 | 4112 MB | no error | CUFFT_INVALID_PLAN | CUFFT_INVALID_PLAN |
--------------±--------±-----------------------±-----------------------±-----------------------+[/codebox]
I have no consistent explanation on above table.
for example, (n1,n2,n3) = (511,511,511) shows “out of memory” but
(n1,n2,n3) = (512,512,512) works without error
Does anyone have ideas?
problem is still the same even installing latest cuda 2.3 posted in
[url=“http://forums.nvidia.com/index.php?showtopic=102548&pid=577902&mode=threaded&start=#entry577902”]http://forums.nvidia.com/index.php?showtop...rt=#entry577902[/url]
does anyone have the same experience?
Maybe the problem lies in the memory-bound transpose program. Have you solved it?
I am having the same exact problem. The image processing program that I am working with uses cufftPlan1d CUFFT_R2C followed by CUFFT_C2R to filter images.
If I set 1024 as my transform size (nx) and 1000 (height of the image) as the number of transforms (batch) everything works fine.
If I set 2048 as my transform size (nx) and 2000 (height of the image) as the number of transforms (batch) this is the error I get: CUFFT_EXEC_FAILED
What are the official limits of cufftPlan1d?
BTW my Tesla GPU has 3GB memory.
I am being told these sizes should work, so the problem is likely elsewhere. Are you using CUDA 4.0? Could you attach a small, self-contained, app that reproduces the problem?
The guy who wrote the program originaly was using half height of the image as a dimension of blockdim of cuda kernel operations. So 1024/2 = 512 and is withn limits. 2048/2 exceeds 512 which exceeds the maximum number of threads in a block: 512. See reference below. The next cuda operation to be called was the cufftExecR2C. For whatever reason the first cuda operation wasn’t failing but the cufftExecR2C which followed was. I figure the GPU was fritzed out by the first operation and the next operation to come along crashed.
The total size of a block is limited at 512 threads
From page 2/10 of this reference manual:
It looks like the apps is missing some error checking upstream of the CUFFT call. Since the error status isn’t checked and cleared, it then gets reported on a subsequent CUDA operation, which in this case happened to be inside the CUFFT call. As this can be very confusing(as the present case demonstrates), I recommend checking every API call and every kernel launch. It seems like in your case there is a previous kernel launch that is not checked. To catch both synchronously reported pre-launch errors and asynchronously kernle failures in non-production code I use the following handy macro:
// Macro to catch CUDA errors in kernel launches
#define CHECK_LAUNCH_ERROR()                                          \
do {        \
    /* Check synchronous errors, i.e. pre-launch */                   \
    cudaError_t err = cudaGetLastError();                             \
    if (cudaSuccess != err) {                                         \
        fprintf (stderr, "Cuda error in file '%s' in line %i : %s.\n",\
                 __FILE__, __LINE__, cudaGetErrorString(err) );       \
        exit(EXIT_FAILURE);                                           \
    /* Check asynchronous errors, i.e. kernel failed (ULF) */         \
    err = cudaThreadSynchronize();                                    \
                 __FILE__, __LINE__, cudaGetErrorString( err) );      \
} while (0)
