I am trying to use GPUs for direct numerical simulation of fluid flow, and one of the things I need to accomplish is a 3D FFT of a large set of data (1024^3 hopefully). I have worked with cuFFT quite a bit for smaller cases that fit on a single GPU, but I am now trying to expand the resolution which will require the memory of multiple GPUs.
I have written some sample code (below) to take the forward and inverse FFT of a function as a simple test. I tried to follow the NVidia sample code simplecufft_2d_mgpu as closely as possible for the first test, but instead of creating memory on the host and transferring it to the GPUs, I am using managed memory arrays, but still performing the same memory copies to make sure the data is aligned properly.
I seem to have gotten the code working for the smaller domain sizes, from 64^3 to 256^3, but when I attempt to go to 512^3, or preferably, 1024^3, I get an error in the cuFFTXtSetGPU function.
Usually I have a good idea of what I can do as far as troubleshooting goes, but for this one I am stumped. I am hoping that someone might be able to take my code and run it to see if they have the same issues, or if anyone has come across a similar problem before. I have pasted the code below, but it is also available on my github at GitHub - bblakeley/Multi_GPU_FFT_check: A small routine that initializes a set of data, takes the forward and inverse Fourier Transform, and then compares that output to the original function. This version utilizes multiple GPUs connected to a single host device to perform the kernel calculations and Fourier Transforms.. Note that the simulation size can be changed in lines 21-23 which define the number of grid points used.
Thanks in advance for the help!
Edit: I forgot to mention that I am using CUDA 8.0 on two different setups: one setup is using a TitanXp as GPU0 and a Quadro K2000 as GPU1. On this setup, I receive the *XtSetGPU error when trying a 512^3 simulation. The other setup is on Amazon Web Services (p2.8xlarge instance) which has two Tesla K80’s. In this case, I can run the 512^3 case, but get the same *XtSetGPU error when attempting to run at 1024^3.
// Multiple GPU version of cuFFT_check that uses multiple GPU's
// This program creates a real-valued 3D function sin(x)*cos(y)*cos(z) and then
// takes the forward and inverse Fourier Transform, with the necessary scaling included.
// The output of this process should match the input function
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <complex.h>
// includes, project
#include <cuda_runtime.h>
#include <device_launch_parameters.h>
#include <cufft.h>
#include <cuComplex.h>
//CUFFT Header file
#include <cufftXt.h>
#define NX 512
#define NY 512
#define NZ 512
#define NZ2 (NZ/2+1)
#define NN (NX*NY*NZ)
#define L (2*M_PI)
#define TX 8
#define TY 8
#define TZ 8
int divUp(int a, int b) { return (a + b - 1) / b; }
__device__
int idxClip(int idx, int idxMax){
return idx > (idxMax - 1) ? (idxMax - 1) : (idx < 0 ? 0 : idx);
__device__
int flatten(int col, int row, int stack, int width, int height, int depth){
return idxClip(stack, depth) + idxClip(row, height)*depth + idxClip(col, width)*depth*height;
// Note: using column-major indexing format
__global__
void initialize(int NX_per_GPU, int gpuNum, cufftDoubleComplex *f1, cufftDoubleComplex *f2)
const int i = blockIdx.x * blockDim.x + threadIdx.x;
const int j = blockIdx.y * blockDim.y + threadIdx.y;
const int k = blockIdx.z * blockDim.z + threadIdx.z;
if ((i >= NX_per_GPU) || (j >= NY) || (k >= NZ)) return;
const int idx = flatten(i, j, k, NX, NY, NZ);
// Create physical vectors in temporary memory
double x = i * (double)L / NX + (double)gpuNum*NX_per_GPU*L / NX;
double y = j * (double)L / NY;
double z = k * (double)L / NZ;
// Initialize starting array
f1[idx].x = sin(x)*cos(y)*cos(z);
f1[idx].y = 0.0;
f2[idx].x = 0.0;
f2[idx].y = 0.0;
return;
__global__
void scaleResult(int NX_per_GPU, cufftDoubleComplex *f)
f[idx].x = f[idx].x / ( (double)NN );
f[idx].y = f[idx].y / ( (double)NN );
return;
int main (void)
int i, j, k, idx, NX_per_GPU;
// double complex test;
// Set GPU's to use and list device properties
int nGPUs = 2, deviceNum[nGPUs];
for(i = 0; i<nGPUs; ++i)
deviceNum[i] = i;
cudaSetDevice(deviceNum[i]);
cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, deviceNum[i]);
printf(" Device name: %s\n", prop.name);
printf(" Memory Clock Rate (KHz): %d\n",
prop.memoryClockRate);
printf(" Memory Bus Width (bits): %d\n",
prop.memoryBusWidth);
printf(" Peak Memory Bandwidth (GB/s): %f\n\n",
2.0*prop.memoryClockRate*(prop.memoryBusWidth/8)/1.0e6);
printf("Running Multi_GPU_FFT_check using %d GPUs on a %dx%dx%d grid.\n",nGPUs,NX,NY,NZ);
// Initialize input data
// Split data according to number of GPUs
NX_per_GPU = NX/nGPUs; // This is not a good solution long-term; needs more work for arbitrary grid sizes/nGPUs
// Declare variables
cufftDoubleComplex *u;
cufftDoubleComplex *u_fft;
// Allocate memory for arrays
cudaMallocManaged(&u, sizeof(cufftDoubleComplex)*NN );
cudaMallocManaged(&u_fft, sizeof(cufftDoubleComplex)*NN );
// Launch CUDA kernel to initialize velocity field
const dim3 blockSize(TX, TY, TZ);
const dim3 gridSize(divUp(NX_per_GPU, TX), divUp(NY, TY), divUp(NZ, TZ));
for (i = 0; i<nGPUs; ++i){
int idx = i*NX_per_GPU*NY*NZ; // sets the index value of the data to send to each gpu
initialize<<<gridSize, blockSize>>>(NX_per_GPU, deviceNum[i], &u[idx], &u_fft[idx]);
// Synchronize both GPUs before moving forward
cudaDeviceSynchronize();
// Initialize CUFFT for multiple GPUs //
// Initialize result variable used for error checking
cufftResult result;
// Create empty plan that will be used for the FFT
cufftHandle plan;
result = cufftCreate(&plan);
if (result != CUFFT_SUCCESS) { printf ("*Create failed\n"); return 1; }
// Tell cuFFT which GPUs to use
result = cufftXtSetGPUs (plan, nGPUs, deviceNum);
if (result != CUFFT_SUCCESS) { printf ("*XtSetGPUs failed: code %i\n", result); return 1; }
// Create the plan for the FFT
size_t *worksize; // Initializes the worksize variable
worksize =(size_t*)malloc(sizeof(size_t) * nGPUs); // Allocates memory for the worksize variable, which tells cufft how many GPUs it has to work with
// Create the plan for cufft
result = cufftMakePlan3d(plan, NX, NY, NZ, CUFFT_Z2Z, worksize);
if (result != CUFFT_SUCCESS) { printf ("*MakePlan* failed: code %d \n",(int)result); exit (EXIT_FAILURE) ; }
printf("The size of the worksize is %lu\n", worksize[0]);
// Initialize transform array - to be split among GPU's and transformed in place using cufftX
cudaLibXtDesc *u_prime;
// Allocate data on multiple gpus using the cufft routines
result = cufftXtMalloc(plan, (cudaLibXtDesc **)&u_prime, CUFFT_XT_FORMAT_INPLACE);
if (result != CUFFT_SUCCESS) { printf ("*XtMalloc failed\n"); exit (EXIT_FAILURE) ; }
// Copy the data from 'host' to device using cufftXt formatting
result = cufftXtMemcpy(plan, u_prime, u, CUFFT_COPY_HOST_TO_DEVICE);
if (result != CUFFT_SUCCESS) { printf ("*XtMemcpy failed, code: %d\n",result); exit (EXIT_FAILURE); }
// Perform FFT on multiple GPUs
printf("Forward 3d FFT on multiple GPUs\n");
result = cufftXtExecDescriptorZ2Z(plan, u_prime, u_prime, CUFFT_FORWARD);
if (result != CUFFT_SUCCESS) { printf ("*XtExecZ2Z failed\n"); exit (EXIT_FAILURE); }
////////// Apparently re-ordering the data prior to the IFFT is not necessary (gives incorrect results)////////////////////
// cudaLibXtDesc *u_reorder;
// result = cufftXtMalloc(plan, (cudaLibXtDesc **)&u_reorder, CUFFT_XT_FORMAT_INPLACE);
// if (result != CUFFT_SUCCESS) { printf ("*XtMalloc failed\n"); exit (EXIT_FAILURE) ; }
// // Re-order data on multiple GPUs to natural order
// printf("Reordering the data on the GPUs\n");
// result = cufftXtMemcpy (plan, u_reorder, u_prime, CUFFT_COPY_DEVICE_TO_DEVICE);
// if (result != CUFFT_SUCCESS) { printf ("*XtMemcpy failed\n"); exit (EXIT_FAILURE); }
// Perform inverse FFT on multiple GPUs
printf("Inverse 3d FFT on multiple GPUs\n");
result = cufftXtExecDescriptorZ2Z(plan, u_prime, u_prime, CUFFT_INVERSE);
// Copy the output data from multiple gpus to the 'host' result variable (automatically reorders the data from output to natural order)
result = cufftXtMemcpy (plan, u_fft, u_prime, CUFFT_COPY_DEVICE_TO_HOST);
// Scale output to match input (cuFFT does not automatically scale FFT output by 1/N)
scaleResult<<<gridSize, blockSize>>>(NX_per_GPU, &u_fft[idx]);
// Synchronize GPUs
// Test results to make sure that u = u_fft
double error = 0.0;
for (i = 0; i<NX; ++i){
for (j = 0; j<NY; ++j){
for (k = 0; k<NZ; ++k){
idx = k + j*NZ + NZ*NY*i;
// error += (double)u[idx].x - sin(x)*cos(y)*cos(z);
error += (double)u[idx].x - (double)u_fft[idx].x;
// printf("At idx = %d, the value of the error is %f\n",idx,(double)u[idx].x - (double)u_fft[idx].x);
// printf("At idx = %d, the value of the error is %f\n",idx,error);
printf("The sum of the error is %4.4g\n",error);
// Deallocate variables
// Free malloc'ed variables
free(worksize);
// Free cuda malloc'ed variables
cudaFree(u);
cudaFree(u_fft);
// Free cufftX malloc'ed variables
result = cufftXtFree(u_prime);
if (result != CUFFT_SUCCESS) { printf ("*XtFree failed\n"); exit (EXIT_FAILURE); }
// result = cufftXtFree(u_reorder);
// if (result != CUFFT_SUCCESS) { printf ("*XtFree failed\n"); exit (EXIT_FAILURE); }
// Destroy FFT plan
result = cufftDestroy(plan);
if (result != CUFFT_SUCCESS) { printf ("cufftDestroy failed: code %d\n",(int)result); exit (EXIT_FAILURE); }
return 0;
