The Lambert W function is the solution w of w*exp(w)=z. It is named after the Swiss mathematician Johann Heinrich Lambert (1728-1777), although (in keeping with Stigler’s law of eponymy) it was originally examined by his more famous compatriot Leonard Euler, who, however, credited Lambert with some of the underlying ideas in the relevant publication:
Leonard Euler, “De serie Lambertina plurimisque eius insignibus proprietatibus,” (On Lambert’s series and its many distinctive properties) Acta Academiae Scientiarum Imperialis Petropolitanae pro Anno MDCCLXXIX, Tomus III, Pars II, (Proceedings of the Imperial Academy of Sciences of St. Petersburg for the Year 1779, volume 3, part 2, Jul. - Dec.), St. Petersburg: Academy of Sciences 1783, pp. 29-51 (scan by Bavarian State Library, Munich)
After a slumber of some 200 years, the function was rediscovered (and named after Lambert) in the 1990s for use in computer algebra packages, but there have since been various applications in the physical sciences, a useful overview of which can be found in Wikipedia. My own interest arose from using it as a building block for the computation of the inverse of the principal branch of the gamma function.
The Lambert W function is multi-branched, but when restricted to the real numbers, solving y*exp(y)=x, there are just two branches, commonly referred to as W0 (the principal branch) for x in [-exp(-1), ∞] and W-1 for x in [-exp(-1), 0). As in cases of other multi-branched functions such as the square root, the principal branch is usually the one of interest, and is the one computed by the single-precision implementation lambert_w0f
below.
The numerical computation of the Lambert W function is an area of active research, with most of the focus either on piecewise rational approximations or on starting approximations of various kinds coupled with functional iteration schemes.
I created lambert_w0f
as a starting point for further investigations. In its present form it provides results with good accuracy, with maximum error of 2.56303 ulps across the entire input domain. Performance is reasonably good, with the cost of logarithmic and exponential functions mitigated as best as possible, for example by using device intrinsics. I am using simple Newton iterations, as the iterations of higher order, like Halley’s (third order) and Schröder’s method (fifth order), often advocated in the literature, seem not to perform as well as one might expect when executed in finite-precision floating-point arithmetic. In particular three Newton iterations provide more accurate results than two Halley iterations.
[ Code below updated 7/21/2022, 7/25/2022, 7/26/2022, 7/27/2022, 7/29/2022, 8/3/2022, 9/11/2022, 9/18/2022, 1/17/2023 ]
Copyright (c) 2022-2023, Norbert Juffa
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
1. Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
__forceinline__ __device__ float raw_rcp (float a)
float r;
asm ("rcp.approx.ftz.f32 %0,%1;" : "=f"(r) : "f"(a));
return r;
__forceinline__ __device__ float raw_sqrt (float a)
float r;
asm ("sqrt.approx.ftz.f32 %0,%1;" : "=f"(r) : "f"(a));
return r;
__forceinline__ __device__ float raw_ex2 (float a)
float r;
asm ("ex2.approx.ftz.f32 %0,%1;" : "=f"(r) : "f"(a));
return r;
__forceinline__ __device__ float raw_lg2 (float a)
float r;
asm ("lg2.approx.ftz.f32 %0,%1;" : "=f"(r) : "f"(a));
return r;
/* Compute exp(a) * 2**scale. Max ulp err = 0.86565 */
__forceinline__ __device__ float expf_scale (float a, int scale)
const float flt_int_cvt = 12582912.0f; // 0x1.8p23
float f, r, j, t;
int i;
// exp(a) = 2**i * exp(f); i = rintf (a / log(2))
j = fmaf (1.442695f, a, flt_int_cvt); // // 0x1.715476p0 // log2(e)
t = j - flt_int_cvt;
f = fmaf (t, -6.93145752e-1f, a); // -0x1.62e400p-1 // log_2_hi
f = fmaf (t, -1.42860677e-6f, f); // -0x1.7f7d1cp-20 // log_2_lo
i = __float_as_int (j);
// approximate r = exp(f) on interval [-log(2)/2, +log(2)/2]
r = 1.37805939e-3f; // 0x1.694000p-10
r = fmaf (r, f, 8.37312452e-3f); // 0x1.125edcp-7
r = fmaf (r, f, 4.16695364e-2f); // 0x1.555b5ap-5
r = fmaf (r, f, 1.66664720e-1f); // 0x1.555450p-3
r = fmaf (r, f, 4.99999851e-1f); // 0x1.fffff6p-2
r = fmaf (r, f, 1.00000000e+0f); // 0x1.000000p+0
// exp(a) = 2**(i+scale) * r;
r = __int_as_float (((i + scale) << 23) + __float_as_int (r));
return r;
Compute the principal branch of the Lambert W function, W_0. The maximum
error in the positive half-plane is 1.49923 ulps and the maximum error in
the negative half-plane is 2.56303 ulps; a total of 76403840 results are
not correctly rounded.
__device__ float lambert_w0f (float z)
const float MY_INF = __int_as_float (0x7f800000);
const float em1_fact_0 = 0.625529587f; // exp(-1)_factor_0
const float em1_fact_1 = 0.588108778f; // exp(-1)_factor_1
const float qe1 = 2.71828183f / 4.0f; // exp(1)/4
float e, w, num, den, rden, redz, y, r;
if (isnan (z) || (z == MY_INF) || (z == 0.0f)) return z + z;
if (fabsf (z) < 1.220703125e-4f) return fmaf (-z, z, z); // 0x1.0p-13
redz = fmaf (em1_fact_0, em1_fact_1, z); // z + exp(-1)
if (redz < 0.0625f) { // expansion at -(exp(-1))
r = raw_sqrt (redz);
w = -1.23046875f; // -0x1.3b0000p+0
w = fmaf (w, r, 2.17185670f); // 0x1.15ff66p+1
w = fmaf (w, r, -2.19554094f); // -0x1.19077cp+1
w = fmaf (w, r, 1.92107077f); // 0x1.ebcb4cp+0
w = fmaf (w, r, -1.81141856f); // -0x1.cfb920p+0
w = fmaf (w, r, 2.33162979f); // 0x1.2a72d8p+1
w = fmaf (w, r, -1.00000000f); // -0x1.000000p+0
} else {
/* Compute initial approximation. Based on: Roberto Iacono and John
Philip Boyd, "New approximations to the principal real-valued branch
of the Lambert W function", Advances in Computational Mathematics,
Vol. 43, No. 6, December 2017, pp. 1403-1436
y = fmaf (2.0f, raw_sqrt (fmaf (qe1, z, 0.25f)), 1.0f);
y = raw_lg2 (raw_rcp (fmaf (0.31819974f, raw_lg2 (y), 1.0f)) *
fmaf (1.15262585f, y, -0.15262585f));
w = fmaf (1.41337042f, y, -1.0f);
/* perform Newton iterations to refine approximation to full accuracy */
const float l2e = 1.44269504f; // log2(exp(1))
e = raw_ex2 (fmaf (l2e, w, -3.0f));
num = fmaf (w, e, -0.125f * z);
den = fmaf (w, e, e);
rden = raw_rcp (den);
w = fmaf (-num, rden, w);
e = expf_scale (w, -3);
return w;
