I was trying to install Archiconda as it was told Anaconda is not supported on aarch64 as per this link:
but I am getting some errors when following the steps ( after step 2) provided in that link as shown below:
Pls let us know how to resolve this error and proceed further:
root@linux:/usr/local/bin# export PATH=$HOME/archiconda3/bin:$PATH
root@linux:/usr/local/bin# conda config --add channels gaiar && \conda config --add channels conda-forge &&
conda config --add channels c4aarch64 &&
conda update -n base --all &&
conda install -y python=3.6.7 libiconv &&
conda install -y conda-build &&
conda install -y anaconda-client
Warning: ‘gaiar’ already in ‘channels’ list, moving to the top
Warning: ‘conda-forge’ already in ‘channels’ list, moving to the top
Warning: ‘c4aarch64’ already in ‘channels’ list, moving to the top
Solving environment: failedCondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/repodata.json.bz2
Elapsed: -An HTTP error occurred when trying to retrieve this URL.
HTTP errors are often intermittent, and a simple retry will get you on your way.If your current network has https://www.anaconda.com blocked, please file
a support request with your network engineering team.SSLError(MaxRetryError(‘HTTPSConnectionPool(host='repo.anaconda.com', port=443): Max retries exceeded with url: /pkgs/main/noarch/repodata.json.bz2 (Caused by SSLError(SSLError(“bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')])”)))’))
