Another segmentation fault with compiled nvfortran code
This is another test case from the WHIZARD test suite,which segfaults when compiled with nvfortran, but works with gfortran, Intel, and NAG compilers.
seg_fault_case.f90 (11.8 KB)
(gdb) run
Starting program: <...>/whizard_test
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
 Mode = 0
 calling importing component
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff5e7d47e in __GI___libc_free (mem=0x547834386a81b1f1) at ./malloc/malloc.c:3368
3368	./malloc/malloc.c: No such file or directory.
(gdb) bt
#0  0x00007ffff5e7d47e in __GI___libc_free (mem=0x547834386a81b1f1) at ./malloc/malloc.c:3368
#1  0x0000000000409c15 in process_configurations::process_configuration_setup_component () at main_ut.f90:363
#2  0x000000000040bb4f in process_configurations_uti::prepare_test_library () at main_ut.f90:398
#3  0x000000000040cb05 in main_ut () at main_ut.f90:410
This is another isolated single case from our main testsuite, posted here:
Thanks Juergen, I’ve filed TPR #33503 to report this issue.
Note that I was unable to reproduce the seg fault, but rather see a double free when exiting the “process_configuration_setup_component” subroutine. Though likely it’s the same root cause.
-Mat
