Segmentation fault with nvfortran 23.1
This is another segmentation fault from our test suite on valid code:
main_ut.f90 (45.9 KB)
leading to the following segmentation fault:
Program received signal SIGSEGV, Segmentation fault.
0x000000000041c4b1 in process_config::process_config_data_init () at main_ut.f90:1348
1348	    config%n_in = config%process_def%get_n_in ()
(gdb) bt
#0  0x000000000041c4b1 in process_config::process_config_data_init () at main_ut.f90:1348
#1  0x000000000041caf7 in process::process_init () at main_ut.f90:1406
#2  0x000000000041d02e in processes_uti::processes_2 () at main_ut.f90:1443
#3  0x000000000041d7d7 in main_ut () at main_ut.f90:1451
(gdb)
Another case from our test suite:
Thanks Juergen, assigned to TPR #33592.
