Is there any Event nodes or other nodes in Action Graph related to “Play” and “Stop”, for example, if “Play” is pressed, the event will be triggered once (and only once)?
In the Event Category look for On Stage Event
and in the properties section you can specify which event you want to trigger such as Play and Stop.
Great! It works!
