I am hitting a really hard to fix issue trying to run Jetson-containers on a Jetson Orin Nano dev kit.
This is a fresh install of JP6.1(rev1) and I am finding that my docker daemon won’t start due to network issues and there is no docker0 ethernet adaptor.
EBU[2024-12-19T12:44:58.617458063+10:00] daemon configured with a 15 seconds minimum shutdown timeout
DEBU[2024-12-19T12:44:58.617503149+10:00] start clean shutdown of all containers with a 15 seconds timeout...
DEBU[2024-12-19T12:44:58.619765945+10:00] Cleaning up old mountid : start.
INFO[2024-12-19T12:44:58.620166628+10:00] stopping event stream following graceful shutdown error="<nil>" module=libcontainerd namespace=moby
DEBU[2024-12-19T12:44:58.620655019+10:00] Cleaning up old mountid : done.
failed to start daemon: Error initializing network controller: error obtaining controller instance: failed to register "bridge" driver: unable to add return rule in DOCKER-ISOLATION-STAGE-1 chain: (iptables failed: iptables --wait -A DOCKER-ISOLATION-STAGE-1 -j RETURN: iptables v1.8.7 (nf_tables): RULE_APPEND failed (No such file or directory): rule in chain DOCKER-ISOLATION-STAGE-1
(exit status 4))
