After reflash with latest Jetpack via SDK Manager Docker do not likes to run
Hello
after relashing vNvidia Orin Developer Kit (64GB) docker refuses run at all.
running dockerd --debug outputs:
failed to start daemon: Error initializing network controller: error obtaining controller instance: failed to register “bridge” driver: unable to add return rule in DOCKER-ISOLATION-STAGE-1 chain: (iptables failed: iptables --wait -A DOCKER-ISOLATION-STAGE-1 -j RETURN: iptables v1.8.7 (nf_tables): RULE_APPEND failed (No such file or directory): rule in chain DOCKER-ISOLATION-STAGE-1
(exit status 4))
deeper examination shows that network interface docker0 do not exists.
remowing and purging docker related packages and reinstall them back do not help.
Looks like postinstall scripts do not create proper network device/s
How to make Docker run correctly within latest JetPack 6.x ?
Many warm Thanks in advance
Jakub
We don’t meet this error in our environment.
But it looks like you are facing a similar issue as below.
Could you try the WAR to see if it helps?
I repeated steps mentioned - works until reboot. After reboot docker0 network interface vanish, and needs be manually save.
Is there any method to make changes in networks configuration permament, pls?
Many Thanks in advance.
with Best Regards,
Jakub
Hi again,
problem solved,
Many warm Thanks for help.
with Best Regards,
Jakub
