I installed aodt-1.4.0 in my linux machine following the instructions on this page: Installation — Aerial Omniverse Digital Twin
However, after the installation, my simulation is missing the option of “Aerial” in the drop down menu and missing the “create Panel” option in Stage widget as expected in Step 3 in Validation section in the tutorial. What did i miss? Are there any extensions/other containers i need to install ?
You can right click anywhere in the Stage widget and you will find Panel under create. You are correct, the “Aerial” option is not available and not neccesary.
Unfortunately I dont have the “Aerial” or “Panel”
option at all. Please see screenshot attached below
Hi @apramanik2
Could you try either attaching a worker or entering live mode first and then find Panel again?
