This is happening to me with GLM-5.2, so I assume it’s a widespread issue. I made API requests with 5 to 10-minute intervals between each one, and I still received error 429. This started happening yesterday. I didn’t had this issue before.
I’m not sure. If a model has heavy usage, doesn’t that mean the queue for each request is long? I.e. waiting 1-4 minutes for a response, and if you don’t get the response, the request is killed at the 5 minute mark. But this limit is weird. Honestly these quirks of the API should be documented (inb4 “no one reads the docs anyway” and “you WILL accept the silent changes because ‘it’s free’”).
I had this problem all day long before it started working again—though only for an hour—and now I’m back to getting that endless 429 error. It seems a limit has quietly been introduced that now applies for 24 hours (possibly 40 requests), but this is just my guess, and I hope I’m wrong—though for now, my theory keeps nagging at me.
In my case, it’s a limit that resets after 1 hour approx, I think you can do 4-6 request and after you’ll get error 429 again, even if you implement sleep between API calls.
That happened to my main account api key and even after 24hr of waiting it’s still giving me the error so I went to use my backup account and it worked for like ten requests maybe and then started to give me this error too
Even if I give it at least five or four minutes between every call. I thought that is happening only for me
Well, this issue has been going on for more than two days now, and I’d like to hear from Nvidia representatives about what’s actually going on, because something has clearly broken, and we don’t even know if this problem will be resolved anytime soon.
I think they did this on purpose, either as a way to stop those users who use AI agents that are flooding the API with endless requests without sleeping between them, or something really broke. I think it’s the first, and there’s nothing you can do about it. It’s their service after all. I hope I’m wrong though.
Bro i don’t think it’s the first one because I let it sleep five minutes between every request and I still get this error so it’s obviously not just that
When GLM-5.1 was available on NIM, the same happened. It was fine for the first few weeks, then suddenly it was more limited, and it reminded me to this exact scenario. But from what some users say here, the entire model catalog is bugged. I don’t know anymore. Does this happen with DeepSeek Flash too?
No. it wouldnt get queued, just declined by the api. this type of limit is in the faq. "Q. How do the rate limits work?
A. The NVIDIA API catalog is a trial experience of NVIDIA NIM, so the number of calls allowed during a certain period of time is designed to serve evaluation and prototyping needs only. The rate of requests will vary per model queried and may vary based on the number of concurrent users."
coming back here; it’s about a 24 hour lock, which is quite odd. even the 429 wave that happened in mid june was only for about an hour or two each, which is odd.
