This is my problem
My problem is the deepseek v4 pro I just use 1 - 5 requests and 429 error appear (why it said that RPM is 40?) and I need to wait 1 - 2 hours just to use it again
Next is glm 5.1, I cant even chat to it it just timed out all the time?
So tell me what to do in the replies so I can now how to fix
hello, are you still getting this issue, or has it been resolved for you? getting the exact same issue here…
Still
I heard that in another popular thread, that they have found a solution… i understand the gist of it, but when i tried it, it didn’t work,. i’m a younger dev and i don’t use nim that often, so i don’t really know all the ins and outs of backend…
here’s the thread: Getting 429 Too many request for NIM cloud api
if you find the solution, would you mind messaging me? much appreciated
ok, thx
hey, have you found a stable solution yet? i’ve managed to get by so far without 429, through some miracle. are you still getting it?
personaly that made so long time that i haven’t trigger that 429 issue, option existe to avoid get stuck 2 hours , but we don’t sharing it you have to found it by your self , all dev that found the answer should keep it for him self because if we leak that answer OpenClaw user will get back and brake down NIM api again … keep working on it i think dev don’t need to be genius to found the way too , that was easy to understud what nvidia have one if you think like API owner and how they can manage hard hit.
hop my little push have help you to think about the better way that API owner can mange the hard rate hit and so how to avoid the limitation <3
Thanks for your words, I definitely will try to find it :D
