Api for audio2face-2d
Im new here, so sorry for my lack of knowledge
im trying to integrate the audio2face-2d api in python. For others models, there is example in many language:
Like here llama-3.1-405b-instruct Model by Meta | NVIDIA NIM
from openai import OpenAI
client = OpenAI(
  base_url = "https://integrate.api.nvidia.com/v1",
  api_key = "$API_KEY_REQUIRED_IF_EXECUTING_OUTSIDE_NGC"
completion = client.chat.completions.create(
  model="meta/llama-3.1-405b-instruct",
  messages=[{"role":"user","content":"Write a limerick about the wonders of GPU computing."}],
  temperature=0.2,
  top_p=0.7,
  max_tokens=1024,
  stream=True
for chunk in completion:
  if chunk.choices[0].delta.content is not None:
    print(chunk.choices[0].delta.content, end="")
But i can’t seems to find the example for this model:
Could someone help me.
+1
same problem! @evainmatthieu44 Give a reply if you found any solutions!
Looks like it’s still in early access and would really appreciate if some one guides on how to get access and make use of the early preview
Hey!
At this time, there’s no available API endpoints for this model - we’ll keep you posted as things change!
