Hi Team,
I tried to add a probe function to src pad of nvstreammux, to crop the buffer from nvstreammux and composite this cropped buffer with the original nvstreammux buffer, so that the nvinfer plugin will infer on the composited buffer. I implemented this function in deepstream-test3-app and it works well. But when I implemented it in deepstream-app, I am able to continuously transfer and composite the frames for around 959 frames and then it crashes reporting the below errors. The below errors change randomly each run. The only clue that I can get is the error “Could not allocate internal buffer for buffer conversion” is triggered by NvBufSurfaceCreate() function.
Any help would be appreciated. Thanks.
Error 1:
Cuda failure: status=700
Error: Could not allocate internal buffer for buffer conversion
Go to error
GPUassert: an illegal memory access was encountered src/modules/cuDCF/cudaCropScaleInTexture2D.cu 865
0:00:38.617924248 21758 0x55cc1d0e48f0 ERROR nvinfer gstnvinfer.cpp:987:get_converted_buffer:<primary_gie_classifier> cudaMemset2DAsync failed with error cudaErrorIllegalAddress while converting buffer
cuGraphicsMapResources failed with error(700) gst_eglglessink_cuda_buffer_copy
0:00:38.617941290 21758 0x55cc1d0e48f0 WARN nvinfer gstnvinfer.cpp:1246:gst_nvinfer_process_full_frame:<primary_gie_classifier> error: Buffer conversion failed
ERROR from primary_gie_classifier: Buffer conversion failed
Debug info: gstnvinfer.cpp(1246): gst_nvinfer_process_full_frame (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier
Error 2:
Go to error
GPUassert: an illegal memory access was encountered src/modules/cuDCF/cudaCropScaleInTexture2D.cu 352
(../inc/nvcudautils) Error ResourceError: e: an illegal memory access was encountered (cudaErrorIllegalAddress) (propagating from /vpi/ext/nvcudautils/src/AllocMem.cpp, function freeMem(), line 283)
(../inc/nvcudautils) Error ResourceError: (propagating from /vpi/ext/nvcudautils/inc/nvcudautils/detail/../AllocMem.h, function operator()(), line 45)
(../inc/nvcudautils) Error ResourceError: (propagating from /vpi/ext/nvcudautils/inc/nvcudautils/detail/../AllocMem.h, function operator()(), line 60)
../../src/hb-object-private.hh:154: Type* hb_object_reference(Type*) [with Type = hb_unicode_funcs_t]: Assertion `hb_object_is_valid (obj)’ failed.
Aborted (core dumped)
Error 3:
Go to error
cuMemcpy2D failed with error(700) gst_eglglessink_cuda_buffer_copy
0:00:35.050961321 26693 0x55aa630f7cf0 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:queueInputBatch(): Failed to make stream wait on event(cudaErrorIllegalAddress)
0:00:35.050977356 26693 0x55aa630f7cf0 WARN nvinfer gstnvinfer.cpp:1098:gst_nvinfer_input_queue_loop:<primary_gie_classifier> error: Failed to queue input batch for inferencing
ERROR from primary_gie_classifier: Failed to queue input batch for inferencing
Debug info: gstnvinfer.cpp(1098): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier
Quitting
My core implementation of this probe function:
gint processing_width = appCtx->config.streammux_config.pipeline_width;
gint processing_height = appCtx->config.streammux_config.pipeline_height;
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (buf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
goto error;
surface = (NvBufSurface *) in_map_info.data;
batch_meta = gst_buffer_get_nvds_batch_meta (buf);
if (batch_meta == NULL) {
g_print("NvDsBatchMeta not found for input buffer.\n");
goto error;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
frame_meta = (NvDsFrameMeta *) (l_frame->data);
NvOSD_RectParams rect_params;
// Scale the entire frame to processing resolution
rect_params.left = 0;
rect_params.top = 0;
rect_params.width = (guint) surface->surfaceList[idx].width;
rect_params.height = (guint) surface->surfaceList[idx].height;
// Scale and convert the frame
NvBufSurfTransform_Error err;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransformParams transform_params;
NvBufSurfTransformRect src_rect;
NvBufSurfTransformRect dst_rect;
NvBufSurface ip_surf;
ip_surf = *surface;
NvBufSurface *dst_surface = NULL;
ip_surf.numFilled = ip_surf.batchSize = 1;
ip_surf.surfaceList = &(surface->surfaceList[idx]);
gint src_left = GST_ROUND_UP_2(rect_params.left);
gint src_top = GST_ROUND_UP_2(rect_params.top);
gint src_width = GST_ROUND_DOWN_2(rect_params.width);
gint src_height = GST_ROUND_DOWN_2(rect_params.height);
// Maintain aspect ratio
double hdest = processing_width * src_height / (double) src_width;
double wdest = processing_height * src_width / (double) src_height;
guint dest_width, dest_height;
if (hdest <= processing_height) {
dest_width = processing_width;
dest_height = hdest;
} else {
dest_width = wdest;
dest_height = processing_height;
cuda_err = cudaSetDevice (surface->gpuId);
cudaStream_t cuda_stream;
cuda_err = cudaStreamCreate (&cuda_stream);
// Configure transform session parameters for the transformation
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = surface->gpuId;
transform_config_params.cuda_stream = cuda_stream;
// Set the transform session parameters for the conversions executed in this thread.
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
if (err != NvBufSurfTransformError_Success) {
g_print("NvBufSurfTransformSetSessionParams failed with error %d\n", err);
goto error;
// Calculate scaling ratio while maintaining aspect ratio
ratio = MIN (1.0 * dest_width / src_width, 1.0 * dest_height / src_height);
if ((rect_params.width == 0) || (rect_params.height == 0)) {
g_print("%s:crop_rect_params dimensions are zero\n",__func__);
goto error;
// Set the transform ROIs for source and destination
src_rect.top = 1150;
src_rect.left = 1650;
src_rect.width = 450;
src_rect.height = 154;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = 989;
dst_rect.height = 637;
// Set the transform parameters
transform_params.src_rect = &src_rect;
transform_params.dst_rect = &dst_rect;
transform_params.transform_flag =
NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC |
NVBUFSURF_TRANSFORM_CROP_DST;
transform_params.transform_filter = NvBufSurfTransformInter_Default;
transform_params.transform_flip = NvBufSurfTransform_None;
NvBufSurfaceCreateParams create_params;
int batch_size= surface->batchSize;
create_params.gpuId = surface->gpuId;
create_params.width = processing_width;
create_params.height = processing_height;
create_params.size = 0;
create_params.isContiguous = true;
create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
create_params.layout = NVBUF_LAYOUT_PITCH;
create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
NvBufSurfaceCreate(&dst_surface, batch_size, &create_params);
if (NvBufSurfaceCreate (&dst_surface, batch_size, &create_params) != 0) {
g_print ("Error: Could not allocate internal buffer for buffer conversion\n");
goto error;
//Memset the memory
NvBufSurfaceMemSet (dst_surface, 0, 0, 0);
g_print("Scaling and converting input buffer for frame %d\n", frame_meta->frame_num);
// Transformation scaling+format conversion
err = NvBufSurfTransform (&ip_surf, dst_surface, &transform_params);
g_print("NvBufSurfTransform failed with error %d while converting buffer\n", err);
goto error;
// Set the composite parameters
NvBufSurfTransformCompositeParams composite_params;
NvBufSurfTransformRect dst_com_rect;
dst_com_rect.top = 0;
dst_com_rect.left = 0;
dst_com_rect.width = 989;
dst_com_rect.height = 637;
composite_params.src_comp_rect = &dst_rect;
composite_params.dst_comp_rect = &dst_com_rect;
composite_params.composite_flag = NVBUFSURF_TRANSFORM_COMPOSITE;
composite_params.input_buf_count = 2;
// Composite input surface and cropped surface into one buffer
err = NvBufSurfTransformComposite (dst_surface, &ip_surf, &composite_params);
g_print("NvBufSurfTransformComposite failed with error %d while compositing buffers\n", err);
goto error;
// Map the buffer so that it can be accessed by CPU
if (NvBufSurfaceMap (dst_surface, 0, 0, NVBUF_MAP_READ) != 0){
goto error;
// Cache the mapped data for CPU access
NvBufSurfaceSyncForCpu (dst_surface, 0, 0);
// Free resources
if (NvBufSurfaceUnMap (dst_surface, 0, 0)){
goto error;
if (NvBufSurfaceUnMap(&ip_surf, 0, 0)) {
goto error;
NvBufSurfaceDestroy (dst_surface);
cudaStreamDestroy (cuda_stream);
gst_buffer_unmap (buf, &in_map_info);
Please help. Thanks.
