You probably don’t need to work on the initrd
for this. I will back up and provide some context.
When the boot environment is running this is its own operating system. Eventually, its one goal is to overwrite itself with Linux. Prior to doing that the environment must be set up, and whatever Linux needs must be loaded. So far an initrd
is not needed, although a device tree might if the boot environment needs access to hardware to set up prior to Linux loading. An example of a requirement is to access the boot device; a “deeper” need would be to understand the filesystem type if we must retrieve content from disk. For example, the kernel Image
might come from an ext4
partition, or from a binary partition. No boot stage driver is needed to retrieve binary content if the device itself can be accessed, but the boot stage requires an ext4
driver to retrieve a kernel Image
from an ext4
formatted partition.
There are many filesystem types. The initrd
itself is a very simple tree-based RAM filesystem understood by most every bootloader. These days a lot of boot environments can handle VFAT or ext4 as well. The XFS filesystem is popular for some large media, and is rarely understood. If your kernel is on an XFS filesystem paritition, then you’d have to put the kernel itself in the initrd
. If instead your kernel is an ext4
“/boot
”, but you have modules in “/lib/modules/
”, and “/lib/modules/
” is itself on XFS, then all is well if and only if the kernel Image
self-contains the XFS driver (an “=y
” configuration, not a module “=m
”). This is because a module to read XFS on an XFS filesystem would be impossible.
As a kind of adapter, imagine this initial ramdisk is a small filesystem with “/lib/modules/
”. The kernel is on ext4
. Because the bootloader understands initrd
and ext4
, we can (A) load the kernel Image
, and then (B) the kernel can load it’s ext4
driver from the initrd
(both the kernel and the bootloader understand initrd
ramdisk filesystems). Now the bootloader does not need to read XFS because handing over control to the Linux kernel allows the Linux kernel to read XFS. At this point the root is “pivoted” to be reparented on the actual disk which runs XFS (the “/boot
” is still on ext4
). This pivot is the “pivot_root
”. The kernel simply thinks the filesystem root is now the XFS disk.
If we had wanted to boot directly to XFS, there would be a requirement to port the driver to the bootloader even though Linux understands XFS in a module. Not even Linux understanding XFS would help if the Image
file is itself on XFS; this would mandate a driver for the bootloader.
Is your driver part of boot? It seems unlikely for a camera. Did you invalidate the existing modules by changing an integrated feature of the kernel Image
? Probably. If you don’t use an initrd
at the moment, then this means you must replace all kernel modules in “/lib/modules/$(uname -r)/kernel/
”, and indirectly, you should change your CONFIG_LOCALVERSION
to obtain a new “uname -r
” (otherwise you have all new modules in the old directory).
But, here’s the part which makes life much more difficult: If you do use an initrd
, then the modules in this are a “minimal” subset of the modules in “/lib/modules/$(uname -r)/kernel/
”. Those are also invalidated and probably won’t load (they might if lucky). If you used “=y
” in the main Image
in combination with an initrd
, then you must likely also recreate a new initrd
with the valid version of the modules which are in that initrd
As far as the module not automatically loading this would be an entirely different topic. Making this as a built-in is likely the wrong way to go about this. Is this camera “plug-n-play”? Is it USB or PCI? This plays a big part in answering. If not plug-n-play, and if the device cannot self-report what it is and where it is, then the device tree is what you need. If the device is USB or some other plug-n-play, then there are “hot plug” changes you can use to associate the driver to the device.
