Hi. I got the following error when converting D-FINE onnx model file into engine file due to lack of Grid sample.
Please let me hear the answers of the following questions.
It seems like JetPack 5.x or 6.x, TensorRT 8.5 or higher are needed. There is a way to install those version on Jetson nano?
If I can’t update the versions for them, can I use plugin file which provides grid sample to resolve the following error when converting onnx to engine file? If so, how to get that plugin file?
My goal is to run D-FINE-Nano detection model on Jetson nano. If there is any method to run it, please let me know.
root@b8dec3925ed8:/workspace/dfine/D-FINE-master# /workspace/system_root/usr/src/tensorrt/bin/trtexec --onnx=“dfine_n_coco_final_v2.onnx” --saveEngine=“model.engine” --fp16
&&&& RUNNING TensorRT.trtexec [TensorRT v8201] # /workspace/system_root/usr/src/tensorrt/bin/trtexec --onnx=dfine_n_coco_final_v2.onnx --saveEngine=model.engine --fp16
[11/16/2025-03:27:48] [I] === Model Options ===
[11/16/2025-03:27:48] [I] Format: ONNX
[11/16/2025-03:27:48] [I] Model: dfine_n_coco_final_v2.onnx
[11/16/2025-03:27:48] [I] Output:
[11/16/2025-03:27:48] [I] === Build Options ===
[11/16/2025-03:27:48] [I] Max batch: explicit batch
[11/16/2025-03:27:48] [I] Workspace: 16 MiB
[11/16/2025-03:27:48] [I] minTiming: 1
[11/16/2025-03:27:48] [I] avgTiming: 8
[11/16/2025-03:27:48] [I] Precision: FP32+FP16
[11/16/2025-03:27:48] [I] Calibration:
[11/16/2025-03:27:48] [I] Refit: Disabled
[11/16/2025-03:27:48] [I] Sparsity: Disabled
[11/16/2025-03:27:48] [I] Safe mode: Disabled
[11/16/2025-03:27:48] [I] DirectIO mode: Disabled
[11/16/2025-03:27:48] [I] Restricted mode: Disabled
[11/16/2025-03:27:48] [I] Save engine: model.engine
[11/16/2025-03:27:48] [I] Load engine:
[11/16/2025-03:27:48] [I] Profiling verbosity: 0
[11/16/2025-03:27:48] [I] Tactic sources: Using default tactic sources
[11/16/2025-03:27:48] [I] timingCacheMode: local
[11/16/2025-03:27:48] [I] timingCacheFile:
[11/16/2025-03:27:48] [I] Input(s)s format: fp32:CHW
[11/16/2025-03:27:48] [I] Output(s)s format: fp32:CHW
[11/16/2025-03:27:48] [I] Input build shapes: model
[11/16/2025-03:27:48] [I] Input calibration shapes: model
[11/16/2025-03:27:48] [I] === System Options ===
[11/16/2025-03:27:48] [I] Device: 0
[11/16/2025-03:27:48] [I] DLACore:
[11/16/2025-03:27:48] [I] Plugins:
[11/16/2025-03:27:48] [I] === Inference Options ===
[11/16/2025-03:27:48] [I] Batch: Explicit
[11/16/2025-03:27:48] [I] Input inference shapes: model
[11/16/2025-03:27:48] [I] Iterations: 10
[11/16/2025-03:27:48] [I] Duration: 3s (+ 200ms warm up)
[11/16/2025-03:27:48] [I] Sleep time: 0ms
[11/16/2025-03:27:48] [I] Idle time: 0ms
[11/16/2025-03:27:48] [I] Streams: 1
[11/16/2025-03:27:48] [I] ExposeDMA: Disabled
[11/16/2025-03:27:48] [I] Data transfers: Enabled
[11/16/2025-03:27:48] [I] Spin-wait: Disabled
[11/16/2025-03:27:48] [I] Multithreading: Disabled
[11/16/2025-03:27:48] [I] CUDA Graph: Disabled
[11/16/2025-03:27:48] [I] Separate profiling: Disabled
[11/16/2025-03:27:48] [I] Time Deserialize: Disabled
[11/16/2025-03:27:48] [I] Time Refit: Disabled
[11/16/2025-03:27:48] [I] Skip inference: Disabled
[11/16/2025-03:27:48] [I] Inputs:
[11/16/2025-03:27:48] [I] === Reporting Options ===
[11/16/2025-03:27:48] [I] Verbose: Disabled
[11/16/2025-03:27:48] [I] Averages: 10 inferences
[11/16/2025-03:27:48] [I] Percentile: 99
[11/16/2025-03:27:48] [I] Dump refittable layers:Disabled
[11/16/2025-03:27:48] [I] Dump output: Disabled
[11/16/2025-03:27:48] [I] Profile: Disabled
[11/16/2025-03:27:48] [I] Export timing to JSON file:
[11/16/2025-03:27:48] [I] Export output to JSON file:
[11/16/2025-03:27:48] [I] Export profile to JSON file:
[11/16/2025-03:27:48] [I] === Device Information ===
[11/16/2025-03:27:48] [I] Selected Device: NVIDIA Tegra X1
[11/16/2025-03:27:48] [I] Compute Capability: 5.3
[11/16/2025-03:27:48] [I] SMs: 1
[11/16/2025-03:27:48] [I] Compute Clock Rate: 0.9216 GHz
[11/16/2025-03:27:48] [I] Device Global Memory: 3963 MiB
[11/16/2025-03:27:48] [I] Shared Memory per SM: 64 KiB
[11/16/2025-03:27:48] [I] Memory Bus Width: 64 bits (ECC disabled)
[11/16/2025-03:27:48] [I] Memory Clock Rate: 0.01275 GHz
[11/16/2025-03:27:48] [I] TensorRT version: 8.2.1
[11/16/2025-03:27:50] [I] [TRT] [MemUsageChange] Init CUDA: CPU +230, GPU +0, now: CPU 248, GPU 2578 (MiB)
[11/16/2025-03:27:51] [I] [TRT] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 248 MiB, GPU 2578 MiB
[11/16/2025-03:27:51] [I] [TRT] [MemUsageSnapshot] End constructing builder kernel library: CPU 277 MiB, GPU 2608 MiB
[11/16/2025-03:27:51] [I] Start parsing network model
[11/16/2025-03:27:51] [I] [TRT] ----------------------------------------------------------------
[11/16/2025-03:27:51] [I] [TRT] Input filename: dfine_n_coco_final_v2.onnx
[11/16/2025-03:27:51] [I] [TRT] ONNX IR version: 0.0.8
[11/16/2025-03:27:51] [I] [TRT] Opset version: 16
[11/16/2025-03:27:51] [I] [TRT] Producer name: pytorch
[11/16/2025-03:27:51] [I] [TRT] Producer version: 2.0.1
[11/16/2025-03:27:51] [I] [TRT] Domain:
[11/16/2025-03:27:51] [I] [TRT] Model version: 0
[11/16/2025-03:27:51] [I] [TRT] Doc string:
[11/16/2025-03:27:51] [W] [TRT] onnx2trt_utils.cpp:366: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[11/16/2025-03:27:51] [W] [TRT] onnx2trt_utils.cpp:392: One or more weights outside the range of INT32 was clamped
[11/16/2025-03:27:51] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:51] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul_1: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:51] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul_2: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:52] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul_2: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:52] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:52] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul_1: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:52] [I] [TRT] /model/decoder/decoder/layers.0/self_attn/MatMul: broadcasting input1 to make tensors conform, dims(input0)=[300,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:52] [I] [TRT] /model/decoder/decoder/layers.0/self_attn/MatMul_1: broadcasting input1 to make tensors conform, dims(input0)=[300,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:52] [I] [TRT] /model/decoder/decoder/layers.0/self_attn/MatMul_2: broadcasting input1 to make tensors conform, dims(input0)=[300,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:53] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul_2: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:53] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:53] [I] [TRT] /model/encoder/encoder.0/layers.0/self_attn/MatMul_1: broadcasting input1 to make tensors conform, dims(input0)=[400,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:53] [I] [TRT] /model/decoder/decoder/layers.0/self_attn/MatMul_2: broadcasting input1 to make tensors conform, dims(input0)=[300,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:53] [I] [TRT] /model/decoder/decoder/layers.0/self_attn/MatMul: broadcasting input1 to make tensors conform, dims(input0)=[300,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:53] [I] [TRT] /model/decoder/decoder/layers.0/self_attn/MatMul_1: broadcasting input1 to make tensors conform, dims(input0)=[300,-1,128][NONE] dims(input1)=[1,128,128][NONE].
[11/16/2025-03:27:53] [I] [TRT] No importer registered for op: GridSample. Attempting to import as plugin.
[11/16/2025-03:27:53] [I] [TRT] Searching for plugin: GridSample, plugin_version: 1, plugin_namespace:
[11/16/2025-03:27:53] [E] [TRT] ModelImporter.cpp:773: While parsing node number 418 [GridSample → “/model/decoder/decoder/layers.0/cross_attn/GridSample_output_0”]:
[11/16/2025-03:27:53] [E] [TRT] ModelImporter.cpp:774: — Begin node —
[11/16/2025-03:27:53] [E] [TRT] ModelImporter.cpp:775: input: “/model/decoder/decoder/layers.0/cross_attn/Reshape_3_output_0”
input: “/model/decoder/decoder/layers.0/cross_attn/Split_output_0”
output: “/model/decoder/decoder/layers.0/cross_attn/GridSample_output_0”
op_type: “GridSample”
attribute {
i: 0
type: INT
attribute {
s: “bilinear”
type: STRING
attribute {
s: “zeros”
type: STRING
[11/16/2025-03:27:53] [E] [TRT] ModelImporter.cpp:776: — End node —
[11/16/2025-03:27:53] [E] [TRT] ModelImporter.cpp:779: ERROR: builtin_op_importers.cpp:4870 In function importFallbackPluginImporter:
[8] Assertion failed: creator && “Plugin not found, are the plugin name, version, and namespace correct?”
[11/16/2025-03:27:53] [E] Failed to parse onnx file
[11/16/2025-03:27:53] [I] Finish parsing network model
[11/16/2025-03:27:53] [E] Parsing model failed
[11/16/2025-03:27:53] [E] Failed to create engine from model.
[11/16/2025-03:27:53] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8201] # /workspace/system_root/usr/src/tensorrt/bin/trtexec --onnx=dfine_n_coco_final_v2.onnx --saveEngine=model.engine --fp16
