I am using Argus camera-api to develop a camera application. The application is working fine with correct configurations , but application crashes when a camera index is given as input with no actual camera device connected to the port.
Scenario: The csi-port 3 is given as input but no camera is connected to the port. I was expecting an error or an exception but the timeout error happens and the application becomes stuck.
After the crash the board needs to be powered down and rebooted to get it back to working condition.
Log snippet from crash:
(NvCamV4l2) Error IoctlFailed: (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setControlValMultiple(), line 792)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function setDeviceControls(), line 1901)
updateOutputSettings: Set Control failed. Use cached values
SCF: Error InvalidState: 2 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 306)
SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function ~EGLStreamProducer(), line 50)
waitForIdleLocked remaining request 103
waitForIdleLocked remaining request 102
waitForIdleLocked remaining request 101
SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 922)
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function destroy(), line 166)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Is this a known issue/limitation and how can this be avoided ?
